Question about Saws
How do I change the blade on a skilsaw 5380 - Saws
4 Suggested Answers
SOURCE: How do I change the blade?
use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
Posted on May 08, 2009
al_kupchella
  • 843 Answers
SOURCE: Skilsaw 5380 Roller Pin Removal
To remove a rolled pin you need to use a punch tool like a small chisel with a constant diameter and a flat tip. They sell these in chisel sets at Sears and other places. Or you might be able to use a bolt of the right diameter and tap it with a hammer. Don't use a nail though, too soft, it will just jam in there. Good luck.
Posted on Sep 01, 2012
Testimonial: "Thanks for the help!"
  • 51251 Answers
SOURCE: How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Posted on Dec 21, 2016
Skillsaw5380 blade change....reverse thread?
Probably RH. That's the usual.
Dec 21, 2017 | Blade Saws
on a circular saw
Dec 21, 2016 | Saws
Table saw motor burning
Sorry, but my advice is to throw it away. With the 5380 anything more than a cord is not worth repairing.
My recommendation is to buy a Makita 5007 series and stay away from Skil.
Jul 12, 2014 | Skilsaw 5380 Circular Saws
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
Aug 28, 2012 | Skilsaw 5380 Circular Saws
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
How to replace a guard spring on a model 367 skilsaw
take blade off and under blade there is a giude around shaft area around housing where sping goes i hope this was helpful
Aug 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
at times
May 08, 2009 | Saws
Saws Logo
62 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
