Question about Whirlpool Duet WFW9550 Washer
Wont turn on makes sound turn on light does not light up
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
The engine was running. i turned it off to get something. came back and it wont start. All lights come on bright , engine makes a single loud click and wont turn over.
This sounds like a bad starter or bad battery connections, make sure the battery is charged, and when you crank the motor make sure the lights dont go out, turn them on and have someone watch to see if they dim out if they stay bright then starter is bad .
Oct 10, 2010 | 2001 Dodge Durango
T.v wont turn on. i ordered a bulb and replaced it thinkin it was the problem. it wont turn on. when i press the on button the light turns green whille it tries to turn on it makes a clicking sound in the...
If it is not a Mitsubishi lamp it could be that. Aftermarket lamps do not make happy with these TVs. I purchased one and learned the hard way, so either replace with Mitsubishi parts or take your chances. No I do not work for Mitsubishi, I just own two of these TVs and have learned from experience.
Aug 16, 2010 | Mitsubishi WD-60735 Projection Television
Car wont start...sometimes
Sounds like a bad starter solenoid, usually cheapest and easiest to replace the starter and solenoid as a unit. It is always best to check for power between the solenoid and the starter with a test light, if the solenoid clicks but the test light doesn't light up you have found the problem in the solenoid.
Apr 28, 2009 | 2003 Pontiac Grand Am
Car wont start. doesnt make any sound when i turn the key
Check your starter next and make sure you have full batt voltage there before you replace it.
Mar 17, 2009 | 1994 Toyota Tercel
2002 peugeot 307 wont start
either starter motor wire to solonoid has come loose or the ignition switch contacts have fallen apart,turn headlights on and see if dash still lights up could be a flat battery.??
Jan 04, 2009 | Peugeot 405 Cars & Trucks
Akia 27 inch tv wont turn on
I WILL NOT BY AKIA TVS no more thay **** cant get parts
Apr 01, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Whirlpool Duet WFW9550 Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal De
