Question about Dell Latitude D600 Notebook
Error code 1000-0123 how to fix. what to buy?
Ran test code 1000-0123 came up. what to do
Reseting error code on blanco dishwasher
My Blanco BSD9XP displayed the same d13 error. I fixed the problem by replacing the thermistor (Part No. 32X2023). The d13 error remained after the fix but disappeared after I ran the dishwasher through the Test Program. Start the Test Program by holding in the Delayed Start button (has a clock image on it) and simultaneously pressing the Start button ( diamond / C) five times. See the attached description of the Test Prgram to understand how it operates. The second page sets out test parameters for the various elements of the dishwasher.
Nov 29, 2013 | Dishwashers
What does Error Code: HD521-2W mean and how to fix it
http://h30434.www3.hp.com/t5/Desktop-Hardware/SMART-Short-Self-Test-Failed-Error-Code-HD521-2W/td-p/1181885
Nov 09, 2013 | Samsung SP2004C 200GB 7200RPM 3.5in 8MB...
How to fix error code 4400:011A on dell inspiron 560 window 7 home premium
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/0f00-133c-error-code-no-suitable-disk-or-media-is/66dcc559-bd4f-4b70-a39e-0dfd7669d596
Mar 24, 2013 | Dell Computers & Internet
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
ERROR CODE 2000-0142
Hard drive is failing. Reseat hard drive cables. If it does not work, have to replace hard drive. probably damage from overheating or powersurges.
May 15, 2010 | Dell Studio 17 Laptop
How to fix a error code 0142 msg 2ooo-o142 msg unit:prive self test failed.stuaus for a dell labtop
Ok well I have a Dell Inspion 1525 and I have been having problems with it the last little while so I ran a diagnoses tests and I got this:
Error: 0142
Msg: Error code 2000-0142
Msg. Hard drive 1- self test unsuccessful status: 79
Just wondering what exactly it is, and how to fix the problem?
Or if I have to reformat my whole computer
  • 1 year ago
Mar 22, 2010 | Computers & Internet
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
Good luck and thanks for using FixYa!!
May 20, 2009 | Dell Computers & Internet
Dell Latitude D600 Notebook Logo
77 people viewed this question
Alun Cox
