Question about Central Machinery 3-1/2 Cubic Ft. Cement Mixer
Bearings for mod 662
What are the bearing sizes on the mixing drum for a model 662 cement mixer
Have a GE WSXH208HWW Spacesaver, Washing Basket is wobbling. What is the problem and can I fix it myself?
2 possible problems. On the outside of the tub front and on the top back are cement counter weights that are bolted to the tub. If they are coming loose, they would cause the tub to go off balance and wobble. If just the stainless inner tub is the one that wobbles, that suggests a bad rear drum bearing. The counter weight problem easy to fix once you get the top and back off and just need re-tightened. The back drum bearing is something even trained techs want to avoid. It requires removing the complete tub/drum assembly from the washer----then splitting the outer tub in half to replace the inner drum and bearing assembly. Cost for parts will be excessive and not worth the repair.
Apr 04, 2015 | GE Washing Machines
MY MINI MIX CEMENT MIXER IS BROKE DRUM WILL NOT TURN WHEN LOADED
This is the food mixer forum, not much cement gets mixed in the kitchen around here, too much danger of a flying rolling pin.
Sep 06, 2014 | Food Mixers
How do you replace the felt on a dbvh512efoww dryer
rear bearing takes care of rear felt is for the open end where it rides, double face tape or rubber cement on housing (not drum) is if has nothing to keep it there
Jan 27, 2018 | GE DBVH512EFWW Dryer
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
Can any body tell me what size the front drum bearing is for a hoover softwave 1100 ,model No A8754 washing machine is ?
You can buy a drum bearing kit on the net or from Espares.co.uk depending where you are..Some kits are sold as a Half drum with prefitted units quite Expensive......
Feb 10, 2011 | Hoover Washing Machines
I just want to know if the mixer is on a cart with wheels when it is operating and the cart moves while the mixer is mixing would the motion of the cart increase the wear on bearings and other parts?
No not at all., To create an additional lateral stress on a bearing that was strong enough to cause extra wear, you would have to accelerate or decelerate the movement with a rocket or at least a very fast car.
Sep 22, 2010 | Hobart A200 Stand Mixer
Washer mod.mav8551aww wables very mush
Check load distribution, spring and struts first.
If it is nothing in there , then it is usually a drum bearing or drum bearing spider problem.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 28, 2009 | Maytag Washing Machines
WASHER DRUM PROBLEM EXCESSICE MOVEMONT
Have you checked the drum bearing? The bearing is on the very bottom attached to the drum. If this bearing has broken it will allow for excessive play in the drum, Also make sure every bolt is secure and tight
Feb 09, 2009 | Washing Machines
Wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Jan 23, 2008 | Indesit W 123 Front Load Washer
Central Machinery 3-1/2 Cubic Ft. Cement Mixer Logo
70 people viewed this question
Top Central Machinery Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Central Machinery Building Material Expert? Answer questions, earn points and help others
