Question about Brother XL-5500 Mechanical Sewing Machine
How to install needle clamp assembly on BL 21 sewing machine
Need also to buy the assembly
mohammed387
  • 1952 Answers
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Posted on Aug 20, 2009
  • 12 Answers
SOURCE: my needle on my brother CS-100 sewing machine
before you do that, make sure that the machine is threaded correctly. often when the needle is threaded from the wrong side, the thread is wrapped around the top wheels incorrectly, or the bobbin is not threaded right, it will cause the needle to get jammed in the bobbin. however, if this does not work, check their hotline and ask the maker what you should do. you can also go to a local sewing machine store and have them take a look at it.
Posted on Nov 21, 2009
SOURCE: needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
Posted on Feb 13, 2010
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
How do i remove the needle clamp assembly from bernina 1090?
Remove the needle bar clamp screw. From the back side of the needle clamp holder, remove the small needle stop screw. The clamp can then be slid down off the end of the needle bar. You may have to swivel the clamp back and forth as you slide it down in order to remove it. Some clamps are fairly tight.
Jul 08, 2014 | Bernina 1008
Brother xl-6562
Check the clamp for a crack it sounds like it may have been broken. Good luck
Jul 21, 2012 | Brother XL-6562 Mechanical Sewing Machine
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
Sewing Machine Model SA2200 How can I change needle? When I loosen needle clamp screw I can remove the old needle but I was unable to insert new needle by pushing it up into shaft. The hole where the...
Best advice is to take the sewing machine to a repair center, where you can buy a new needle and and ask the service person to install for you. If you bring your own needle, you may get charged for the installation.On the other hand, if you buy a needle from them, you might get a free installation.
Try that.
Jan 26, 2011 | Simplicity Sewing Machines
Needle clamp screw broke off and the end part of the screw is still lodged inside the needle bar. How can I get it out? Would appreciate any help!!
Wow! That's sure a tricky situation! Just had a look at my needle clamp screw set-up through a magnifying glass. It seems to me that there is a very small Allen screw just above the needle clamp screw place. Could you use a small Allen key and undo this, hopefully releasing the whole needle clamp assembly. The cheap kits sold in chain stores for repairing glasses may well contain a tiny Allen key. Your next challenge will be to locate a new needle clamp assembly, but a Husqvarna dealer should be able to help you out there. There is an excellent online place for buying spares but I am very sorry I can't remember its name. Try Google? You could try taking it to a hardware store and seeing if someone there can help you with a suggestion on how to remove the screw shank.
Sep 08, 2010 | Husqvarna Designer I
Needle will not stay in? i install needle, tighten thumb screw and the needle falls out??why??
Buy a new pack of needles to make sure you do not have defective needles, if that doesnt work get a new thumb screw and if it still doesnt work you need a new needle bar.
May 25, 2010 | Brother XL-5130 Mechanical Sewing Machine
Needle clamp screw
You can buy a replacement on sew4less.com, it's called a needle clamp assembly. It's about $15. I did this and my problem is I don't know how to get the broken one off (it won't hold a needle anymore). Please please please tell me how you got yours off in the first place!
Nov 07, 2008 | Sewing Machines
Needle holder assembly came off
If you look carefully you should see a small allen head screw on the needle clamp assembly. There should be a J shaped part which goes into a hole on the bottom of the assembly. Reassemble everything,put the assembly back on the needle bar and tighten the screw with an allen wrench.
sewman7
May 21, 2008 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5500 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
