Question about Samsung RS2630SH Side by Side Refrigerator
Defrost problem samsung rs263 - Samsung RS2630SH Side by Side Refrigerator
  • Samsung Master
  • 5,323 Answers
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
Posted on Apr 10, 2015
Rs263. Why does ice door flap only close partially?
Could be the parts that make up that ice chute door that are broken. Example is like a spring or the part itself. The refrigerator will not cool properly with that door not shutting even just one 1/8 of an inch remaining open. That door needs to be repaired soon!
Appliance 911 Sea Breeze
Sep 17, 2015 | Samsung Refrigerators
Freezer door code is reading -25 on a samsung refigrater
Error 25 is fridge defrost fault, could be defrost sensor or defrost heater.
Ian.
Aug 19, 2015 | Samsung Refrigerators
How do I put Samsung modal rb215 lash refrigerator in defrost manual? Evaporator keeps freezing up!
defrost system MUST function automatically in order fro refrigeration to function. It sounds like you have a malfunction in the defrost system. Find the time and advance into defrost cycle. If defrost cycle begins (The fridge will stop running and water will start trickling after a few minutes), replace the timer. if not, you may have defective heater or defrost thermostat.
Jul 01, 2015 | Samsung Refrigerators
The fridge is not cooling, coils frozen, need to access
I believe the panel you want to remove is the lower vent panel. It should come off just by removing the 4 screws. If you have ice buildup it may be holding it in place. Use a hairdryer to defrost. Be cafreful, hair dryers and puddles of water don't mix well... Here is a link to your manual for some troubleshooting options. So unplug, defrost, then reconnect power.
http://downloadcenter.samsung.com/content/UM/201006/20100625100458859/DA68-01890N.PDF
Apr 02, 2015 | Samsung RS263 Black Side-By-Side...
Rs263 refrigerator side not cooling freezer ok
I would first locate the fan & make sure that it is working , this is the first thing to check . You can normally free it up enough to get it working while you order a new one. Let me know how you go
Mick
Aug 11, 2014 | Refrigerators
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
Lost my A4 Tech web cam installer cd
Hi Friend,
You can download the free driver for your webcam from the below links
http://rs263.rapidshare.com/files/73706033/a4tech-pk-635-driver.rar
just copy and paste in the web browser.Since u didn't mention the model name of A4 Tech,the above link will show u all the webcam drivers of A4 Tech model.
Kindly download which is suitable for u and kindly check it out.
Revert back
Regards,
Ayyasam
May 29, 2009 | A4tech PK-635 Webcam
SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Mar 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Every 3 - 4 weeks i have to defrost my samsung side by side fridge freezer with a hair dryer as the cooling system keeps icing up
you have a defrost problem there are Three parts to it a Defrost control board a Defrost Heater and a Defrost bi-metal thermo-disc I would check the heater first it is in the coils you are defrosting
Jun 09, 2008 | Samsung Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
174 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
