Question about Frigidaire Refrigerators
Fghb2844lf1 ice machine is not work - Frigidaire Refrigerators
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FGHB2844LF1, is not producing ice. I suggest turning your ice maker off and taking out the ice tray and dumping any ice that is in the tray. Wait 3-4 hours. Dry the tray out and put it back into position. Turn the ice maker back on. It will take anywhere from 2-3 hours for ice to produce. If your refrigerator is still not producing ice, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
Posted on May 15, 2014
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker does not work how do I fix
Is freezer cold enough to freeze ice ?
There is a wire across the ice tray that must be down into the tray so the ice machine knows there is room for the next batch of ice in the tray.
If the wire is up in the off position ..no ice willbe dumped into the tray.
Is water being supplied to the ice machine ?
If all above is not the problem ..go online and buy a replacement ice machine.
The cost to fix old machine greater than cost of new machine.
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MACHINE DOESN'T WORK I haven't tried to fix
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 08, 2010 | Maytag MSD2352KES Stainless Steel Side by...
Making ice but won't drop it, then the compressor stops working.It is a Ice-o-machine
You can try and adjust your thickness a bit thicker. If this does not help, your hot gas bypass is not working and the evaporator is not warming. You will need a technician.
Apr 21, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Does not make enough ice
Ice machines are rated in pounds per hour. They usually have an arm paddle switch that tells them when they are full or a weight switch that works the same way.
If possible, transfer the produced ice to another container when the machine is full and allow the unit to keep making ice.
This assumes the machine is working properly and that the cubes are solid. (frozen and not watery).
Dec 07, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Nov 07, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
