Question about A4tech FlexiCAM
Why is my program stalling? - A4tech FlexiCAM
  • A4tech Master
  • 10,322 Answers
1st You download Webcam Driver.
my Camera After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Posted on May 20, 2014
Stalling
The timing is off. This needs to reset by a factory technician with a computer program that resets the values accoprdiongly.
Apr 15, 2014 | 2007 Chrysler Pacifica Touring
Itunes stalls
Are you on a mac or pc? If you are on a Mac then I would try repairing your permissions. if you are on a PC I would invest in a registry repair program as you may have some invalid registry entries by the update that is confusing the commands to start the program. Just thinking!!!! Good luck.
May 15, 2017 | Apple iTunes
When you turn a/c on the rpms begin to drop down and go up again and it stalls at intersections, this started as soon as i changed to a new battery
when you disconnect battery your pcm loses it memmory. it has to relearn its program.its going to keep stalling until it relearn to idle .take it to dealer to reset relearn idle on pcm.it would be safer.because stalling car is dangerous in traffic.
Jun 28, 2009 | 2001 Mitsubishi Eclipse Spyder
Focus That stalls
you need a new fuel pump. There was a program to pay for this for 10 years I think for some 2000-01 Foucs. Here's what the letter from Ford says: December 2003 Program 03N01 "Attached is a letter announcing the details of a no-charge program Ford Motor Company will be conducting concerning your vehicle's fuel pump. We have found some 2000-01 Ford Focus vehicles may experience symptoms of engine hesitation, loss of power, surging and other similar symptoms ...... as a rsult of progressive contamination of the fuel pump filters." (in the fuel pump). You may reduce the liklihood of the symptoms occurring by kee[ing the tank at least half full. My recollection is the program was good for 10 years. Ask your local Ford Dealer if your car is eligible for this program.
Jun 14, 2009 | 2003 Ford Focus
Mouse stalls in the middle of page almost seems caged in a 2" cir
are you running too many things in the back ground? If you are hooked up to the internet and have a file sharing program installed on ur pc, this can cause ever app to run slowwww!
Jan 30, 2009 | Targus Bluetooth Laser Mouse...
Engine stalls after starying
I HAD THE same problem.... 87,000 2000 grand cherokee 4.7l
when i let off the gas it might stall. happens 1 to 4 times a day.
so far i have
replaced the crank shaft sensor - it stopped stalling for 3 days $130
cleaned the throttle boddy free
replaced the throttle position sensor $72
replaced the idle air control sensor $132
replaced the map manafold airflow sensor $125
no luck it is still stalling. by the way i have done all the work myself. it was about 30 minutes for most parts
i just ordered a rebuilt ecu or pcu engine control unit. they program in the vin, mileage and part nbr so you gc will recognize it. $185
installed ECU 2 days ago...... so far so good.
good luck
Jul 20, 2008 | Jeep Cherokee Cars & Trucks
Stalling
If you are having this problem in Windows, don't look at your hardware as being the problem.
A stall in Windows startup is usually a service that fails to start and is waiting to time-out. Check you Event Log.
Your problem could possibly be very complicated. If you offer more information, I could give you more help.
Jul 12, 2008 | Gigabyte Slot A GA-7IXE Motherboard
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all A4tech FlexiCAM Questions
A4tech FlexiCAM Logo
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
