Question about LG Heating & Cooling
Why will my AC not run?
When the remote controller is pressed to turn on the AC the indicator lights flash alternately between heat then cool. Fan runs but it seems to be confused weather to heat or cool and in the end does neither. Regards Chris.
  • 393 Answers
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem Air Conditioning Delray Beach
Posted on Aug 15, 2016
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 124 Answers
SOURCE: High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Posted on Oct 26, 2008
  • 66 Answers
SOURCE: error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Posted on Nov 19, 2008
  • 462 Answers
SOURCE: No cool air. Thermostat AUX light turned on
I suggest you call a qualified service repair man. There are as many ways to connect a heat pump as there are people doing them. Nothing is standard industry wide that has anything to do directly with color codes, so it would be meaningless to go into them here. The terminals may be adapted to standard but but the thermostat manufacturer may not follow any terminal designations.
However you may just have an extra wire touching one of the terminals inside the thermostat. You can check this by removing the cover. Look where the wires attach to the terminal screws on the thermostat. Sometimes a new service person cuts the insulation back too far here or in the outdoor or indoor units and a "whisker" from one wire can touch the other terminals. A whisker is not the normal case try and move it away from another terminal if its is touching there. However, you may have jumpers in place especially if you have W, W1, W2... at any of the 3 sections, meaning the outdoor, indoor and thermostat.
If you can tell me the terminal designations R,Y, W1, W2, E, G, O, (B)... at the thermostat and the color thereon each, then at the indoor unit terminals or wire designations and the color there, then at the outdoor unit and the color thereon each terminal or wire designation there. I might be able to help if the above whisker check you don't find anything.:
Posted on Mar 25, 2009
  • 1236 Answers
SOURCE: Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
Posted on May 11, 2009
Van over heats when I use the AC only, when I turn it off it cools back down to normal
I believe your fans are not functioning properly, could be fans or fan switch sensor
press the helpful button
Jan 28, 2016 | OEM 1998 Dodge B3500 VAN Radio / CD Player...
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
Mar 25, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
My air conditioning will not turn on. The thermostat control has only four buttons,two adjusting the temp up or down,one turns the fan on or on auto and the other selects the system cool heat or off. When...
After setting the unit to cool and adjusting the temperature, the compressor should run if the light stops flashing. Check the condenser, if the fan and compressor does not run, check the contactor if it is energized or pulled in. If the contactor is not pulled in there must be no power or the holding coil is open. If the condenser fan is running without the compressor, check your compressor, high pressure switch, and capacitor.
Sep 09, 2011 | Honeywell Heating & Cooling
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
Jul 03, 2009 | Dell XPS M1530 Notebook
left to right...
1. empty
2. e flashers
3.horn, brake lights
4.clock, trunk light, inside light, radio
5. rad. cooling fan relay (AC only)
6. right side running lights
7. left side running lights
8. right high beam and indicator
9. left high beam and indicator
10. right low beam
11. left low beam
12. reverse,turn signal and inst panel
13. main and transfer fuel pumps, auxiliary air reg., ox sensor heater
14. license plate and glove box light
15. wipers
16. rear defogger
17. heater blower (no AC)
18. cig lighter
19. rad cooling fan (no AC)
20. Heater blower (AC)
21. rad cooling fan (AC only)
22. empty
23. Ox sensor, idle stabilizer,seat belt warning relay, (Digifant only, control unit, idle boost control, idle boost valve)
24. inst panel lights, heater control lights
25. reading lamps
26. empty
27. empty
28. empty
Hope this helps...;-)
Apr 17, 2009 | 1992 Volkswagen Fox
Error code of 6 flashing light on circuit board,
Nov 19, 2008 | Heating & Cooling
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
