Question about Nordic Track NordicTrack GX4.0 Recumbent Exercise Cycle
The wire from the reed switch of my Nordictrack GX4.0 is connected to the switch at one end and then wraps around an upright metal bar. This end of the wire is disconnected. Where/how do I re-attach it?
Why does my Nordictrack treadmill c950 have no power to console from board
check the upright wire that run up the right upright. make sure it is connected at both ends and there are no bent pins
Apr 26, 2014 | NordicTrack Exercise & Fitness
Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Nordictrack audiorider r400 checksum fail
Finally tight the flexible cord form keypanel vs display board and then tight the display board vs lower board.
See if you can meassure +5VDC from lower board to display board.
see the block diagram for your final diagnostic.
12_19_2011_5_43_08_pm.gifSincerely. Merry Christmas.
Ernesto cuadra
managua,nicaragua. c.a.
Dec 19, 2011 | Nordic Track Exercise & Fitness
NordicTrack speeding up for no reason
This make all this adjustments:
Make sure the sensor speed is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
Good luck, sincerely.
E.CUADRA
Nov 28, 2011 | Nordic Track NordicTrack A2750 PRO...
My C2255 Nordictrack has been fine for the past couple of years until recently when it started turning off intermittently with no power to the console. Now, the console will not turn on at all. The...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Oct 17, 2011 | Nordic Track C2255 Console (treadmill)
Hi there One of the issues is we are unable to enter the weight (the button doesnt register it is being pressed) Also the start button doesnt register it is being pressed either Thanks
Finally: You must to clean the Key Pad with Spray for cleaner contact, with very caution.11_8_2011_6_53_33_pm.gif
Sep 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
Console getting erratic numbers and motor will not run. i have checked the reed. my father does not remember how tech support had told him to reset console. Was working intermittenly before we checked...
fINALLY: Test the Optical Sensor if have it
http://www.youtube.com/watch?v=E-q-uS4t6so
Aug 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
Hi, nordictrack c2000 has been working ok until today. The belt still goes round and the music is playing, but the screen has gone blank. Everything else is working except nothing is showing on the...
Do the following and see the video:
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check to the Opticar sensor : if have it.
Jun 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
Norda track t5zi when i press go the motor start for about 1 second and then the screen goes dark and then restarts itself. incline works fine. Bought brand new but I have only used this thing a dozen...
May 16, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack GX4.0 Recumbent Exercise Cycle Logo
41 people viewed this question
Top Nordic Track Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nordic Track Audio Player and Recorder Expert? Answer questions, earn points and help others
