Question about Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure Washer 020486
Can a100' water hose be used on my troy-bilt 2700-psi presser washer
  • 376 Answers
SOURCE: Just bought a 10 hp troy bilt chipper used. When
As LeeatCSEb said, It's your float needle and seat not shutting off the flow of gas when your carb bowl is full. Have your needle and seat replaced. Dwain
Posted on May 18, 2009
harlan301
  • 205 Answers
SOURCE: Troy-Bilt Lawn Chipper/Vacuum Model 47035
go to MTD site troy-built is owned by MTD
Posted on Oct 11, 2009
  • 5 Answers
SOURCE: finding a shredder screen for troy-bilt
Just found some parts for my Troybilt Gardenway chipper-vac Model 47279 on this website http://www.partsandservice.com/bin/ipl.cgi
I would think they might have something for your machine.
Posted on Oct 12, 2009
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
  • 1015 Answers
SOURCE: what kind of oil do
I would recommend valvolene srraight 30 weight unless you are using in cold,below 30 degrees F. Then I would go to 10W 30 Thank you. I have used valvolene products for over 30 years in all my four cycle equipment and I have never had an oil related problem.
Posted on Apr 21, 2011
Need instructions on the use of the soap dispenser on a 2700 psi B&S power sprayer
Dear Audience,
Please go to the link provided and view the on line PDF manual. On pages 16 and 17 you will find the directive to apply detergent into the system and maintaining successfully.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/020292%20man.pdf .
If you are having any difficulty , please check out this direct source Troy bilt Pressure Washer Support ManualsOnline com .
Fare. Well.
Sep 24, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My troy-bilt 20486 pressure washer runs but does not spray water
OK just so we are on the same page.
You did turn on the water (right?)
Jun 12, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Jun 08, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Why doe pressure washer keep blowing hose off
Does the hose need to be clamped in place with a jubilee clip?
May 11, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure Washer 020486 Logo
27 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
