Question about Rockford Fosgate T1500-1BDCP 1500 Watt Class-bd Constant Power Amplifier Car Audio Amp
Why is the Protect light - Rockford Fosgate T1500-1BDCP 1500 Watt Class-bd Constant Power Amplifier Car Audio Amp
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
You have an internal short inside the amp
Posted on Aug 26, 2016
The "PROTECT" light indicator came on and now the
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Sep 12, 2011 | Fender 150 Watt PA System
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Apr 25, 2011 | LG Heating & Cooling
Its on protect mode how do i take it off?
Generally if your amplifier goes into protect, you have a bad ground.
Unhook your power wire from the battery and trace your ground wire to the chassis of the vehicle. Strip the paint from the ground location, Put the ground wire back on the grounding location. Tighten the ground wire down securely with no play and hook back up your power wire.
Other cases revolve around the RCA cables.
Unplug the RCA's and see if the protect light goes off.
Plug one in and see if the protect light comes on and then the other.
If the protect light comes on, you have bad patch cables. Replace them and see if your issue is resolved.
If the amplifier was shorted, the system board made have been damaged.
Jul 28, 2010 | Car Audio & Video
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 29, 2010 | Rockford Fosgate Power 1001BD Car Audio...
Model c-700 It turns on but the protect light dosent come on. What's wrong with it
protect light only comes on when theres a short or bad earth as long as power light on your all good you never wanna see protect light on cheers mate]
Oct 17, 2009 | Boss REV-700 Car Audio Amplifier
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
Lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Jan 16, 2008 | Car Audio & Video
Mac-505 amp
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Dec 19, 2007 | Car Audio & Video
Protect light will not turn off!?
In most cases when the protect light is lit, the amplifier's output transistors have failed.
If the amplifier goes into protect with no speaker wires connected to it, it's likely in need of repair.
Nov 26, 2007 | Kole audio QX1-2400D Car Audio Amplifier
Rockford Fosgate T1500-1BDCP 1500 Watt Class-bd Constant Power Amplifier Car Audio Amp Logo
91 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
