Question about Facebook Apps
What is a Tectonic Plate - Facebook Apps
How are earthquakes made?
The earth's crust which is 3 to 45 miles deep is in sections called tectonic plates. These slide againt one another. When they slide, they sometimes snag against each other. That entanglement even cracks the crust. All movement does not create earthquakes. It depends on the direction of the movement and the strength of the movement.
Nov 15, 2017 | Garden
How deep below the earth is the tectonic plates under the surface
the tectonic plates are the earth surface and are around 100 km or 62 miles thick. they are what is known as the lithosphere and consist of 7 or 8 major plates depending how they are defines and many minor plates
for more information to answer your question go google and type in---location of tectonic plates --- and there are pages and sites that explain it all in detail
Feb 28, 2017 | Cars & Trucks
How deep below the earth is the tectonic plates from the surface
Tectonic plates go all the way up to the surface.
Feb 28, 2017 | Miscellaneous
Whats a transform buondary
Hi Michael:
I'm thinking you might be asking about tectonic plates.
When they slide past each other earthquakes are caused.
Here's a link that gives more information.
https://www.google.ca/#q=tectonic+plates+map
Hope this helps you.
Cheers
Jan 26, 2016 | Garden
What does plate tectonic theory mean
Plate tectonics is the theory that Earth's outer shell is divided into several plates that glide over the mantle, the rocky inner layer above the core. The plates act like a hard and rigid shell compared to Earth's mantle.
Feb 20, 2015 | Edu-Science (10166) Telescope
What causes tsunami
Most tsunamis are caused by earthquakes generated in a subduction zone,an area where an oceanic plate is being forced down into the mantle by plate tectonic forces.
Feb 14, 2013 | Computers & Internet
Shifting tectonic plates causes what?
Tectonic plates are also called fault lines.
When the plates shift, they cause friction which results in earthquakes. The severity of a quake is dependent upon the force of the shifting of the plates.
Oct 03, 2011 | i2we Facebook Apps
How a volcanoes is formed?
volcanoes are formed by tectonic plate friction. Asplate rub against each other, they form cracks, gaps, and voids, that can fill with the magma in the earth's mantle. AThis magma is under extremely high pressure, and any crack or gap that it can find, it will use. As a volcano forms above the surface, there will be a ***** or cone that forms above the volcano, and as presure builds underneath, the volcano grows, sometimes to very high altitudes, before it ever eruprts. Sometimes, it will die out, losing it's pressure, and go dormant. Ther is NO SUCH THING as a DEAD vocalno, they just are dormant for longer periods of time. Some of the volcanoes here on earth have erupted alot, others have only erupted sporadically, but If it eprupts even once, then eventually it will erupt again.
Jan 04, 2011 | Computers & Internet
Facebook Apps Logo
43 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
