Question about Xerox DocuPrint C3290 Printer
Reset xerox c3290 - Xerox DocuPrint C3290 Printer
Scanning to mac
Open System Preferences and make sure your scanner is in your computer under Print and Scan.
Then open up Image Capture and click on your scanner. Then click the scan button, which I have circled in red in the image below.
Mar 02, 2013 | Xerox FX DocuPrint C3290 FS Scanner
Copy problems with xerox fx docuprint c3290
Hi you can have a few problems. 1: try cleaning the glass on the scanner. 2. If you have auto document feeder there may be paper or dirt on the lens that the paper passes over. Clean the long lens. 3 if you clean the glass and lens and still have the problem you will most likely need to have it serviced as there may be paper stuck in the drums that the paper passes through. Paper follows a different path when copied versus a straight print. Try to see what path the copy paper is taking and clean it as best as possible. Last trick is to take out toner cartridges and wipe them clean. Shake them forward to back and reinsert. You may have a worn out roller and if this is the case it is usually cheaper to just buy a new printer.
Nov 01, 2012 | Xerox Computers & Internet
Crum error
crum error refers to either toner, or fuser, or transfer belt - the error code is required to go further
Jul 28, 2012 | Xerox DocuPrint C3290 Printer
Docuprint C3290FS error code 0e
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
for more help visit CBR Tech Solutions
Jan 30, 2012 | Xerox DocuPrint C3290 Printer
Ive got a xerox docuprint C3290FS that keeps comong up with this scanner sensor error 062-360, is there any way to fix it besides replacing the upper section of the machine? Thnaks.
Ive got a xerox docuprint c3290fs and everytime we fax it comes up with error 035-701 and it takes a couple of goes then it eventually goes through is there any way we can fix this problem?
Oct 13, 2010 | Xerox DocuPrint C3290 Printer
How do I set my Xerox Docuprint 3290FS colour printer to work without colour cartrige
unfortunately this cannot be done - best you can do is source a replacement chip for the
cartridge - worst, replace the cartridge with either a compatible or genuine one
Aug 13, 2010 | Xerox DocuPrint C3290 Printer
Need to reset c3290 to factory defaults as admin user/pwd unknown
Go to the Xerox.com website and follow the assistance links.
Good luck.
May 21, 2010 | Xerox DocuPrint C3290 Printer
How to print a fax activity report on c3290 fs
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 02, 2010 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Xerox Docuprint 3290FS colour multifunction black overtoning badly then spilling during "calibration", leaving very dark background and blotches of toner cyan overtoning mildly during "calibration",...
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
http://www.office.xerox.com/userdoc/N3225/pdfs/UserGuide.pdf
This is where you find manuals for all Xerox products :
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_CA
Oct 28, 2009 | Xerox DocuPrint C3290 Printer
Xerox DocuPrint C3290 Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
