Question about GE Ovens
What is the cubic ft of a jvm131k002 microwave
Element heats up when we only put oven light on
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Nov 17, 2014 | Whirlpool RMC305PV 30" Built-in Microwave...
My whirlpool gold microwave reads F7
F7 problems with the inverter leave it alone call a professional they generate up to 5000VDC cannot test without proper equipment
Sep 03, 2014 | Whirlpool Gold 5.0 cu. ft. Combination...
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
How many cubic feet is frigidaire washer model FWS833AS1
Good Afternoon Friend, that's a great question!
I show that your Frigidaire washer (FWS833AS1) has a total capacity of 3.1 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect!
Jun 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
HOw to replace light bulb microwave KEMS308
Unit has to be removed from wall top panels removed to replace if can live with out it great bulb is cheap labor 100-150
Jan 24, 2014 | KitchenAid Architect II KEMS308S 30"...
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
I want some one to come to my residence to demonstrate, as I do not know how to start or operate the Microwave oven, Can you give me a number to contact or call?
what city and state do you reside in ... i am a servicer in the dallas ,ft.worth texas area would be glad to make a service call to your residence if you are with travel distance...
toll free 1-877-523-2101 monday -friday 9am to 5 pm thanks
Jan 05, 2011 | Whirlpool Ovens
Have to replace my hotpoint RVM1335WC 001. Need size, watt info
depending on age of microwave it could be 650watt,& 1.5cuft.
Sep 28, 2009 | Ovens
Ovens Logo
81 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
