Question about Home
How to tighten a fresca apus toilet seat - Home
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
olddewsons
  • 38 Answers
SOURCE: toilet seat come loose and no obvious way to
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Posted on Oct 11, 2009
tsolinac
  • 28 Answers
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: The toilet see is not
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Posted on Aug 29, 2010
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do you tighten the posts on a rak toilet
Look where the seat attaches to the toilet bowl. There are 2 nuts underneath.
Those are the nuts you tighten. they will hold the seat firmly.
Aug 19, 2014 | Home
Pipe connector missing
ok then go buy one from Lowes or Home Depot.
Apr 11, 2014 | Fresca FTL2336 Apus One-Piece Square...
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
Oct 24, 2013 | American Standard Church Seats EL270...
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
I purchased a Fresca FTL2336 Apus One-Piece toilet and installed it. I can hear a constant drip of water escaping from the tank causing the toilet to refill every few hours. I have lifted the flapper,...
The flapper may be defective or not seating completely which causes a continuing slow leak until the tank level drops low enough to cause the flush valve to refill it. I find a cheap flapper lasts just as long as more expensive ones and lasts about as long. Arbitrary replacement of the flapper is a regular periodic maintenance item
Feb 16, 2013 | Fresca FTL2336 Apus One-Piece Square...
Toilet seat does not wont to close only using about a month
seat hinges were tightened out of alignment. Loosen platic nuts and tighten snugly, rotate hinges to bein line and tighten
Oct 02, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Loose Toto toilet seat
Sep 06, 2009 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
