Question about Necchi Sewing Machines
What is fundamental attribution error - Necchi Sewing Machines
    Scholar:
  • 47 Answers
Fundamental attribution error My assumption is that a repair technician told you this was the problem with your sewing machine, after you had it in for repair. Is this correct? This is a common way for unprofessional sewing machine repair technicians to say that either they didn't find any problems, or they assumed that the fault was yours rather than the machine. If this is in fact the situation, it is likely that your technician ran the machine briefly, didn't notice anything out of the usual, and moved on. He may or may not have actually fixed whatever problem you were having originally. If you continue to have issues I would recommend seeking out a second opinion.
Posted on May 14, 2014
Accessories for microscope edu science 900 x
from a laboratory supplies retailer
try searching ---laboratory supplies on e-bay
Nov 30, 2016 | Sewing Machines
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
Feb 14, 2016 | Sewing Machines
Why can't I get a good stitch?
bad stitches can be attributed to incorrect thread tensions
if the thread is bunching under the material -tighten the needle thread tension
if it is missing threads or not pulling the top thread up properly adjust the bobbin thread as it may be too tight
Sep 25, 2015 | Sewing Machines
Error code & solution
HI there
can you please inform us what's model of control box? there is no error named E815 !!!! please we need more explain to help you.
thanks and best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 02, 2014 | Juki DDL-8700
Why won't my baby lock ellure plus read my USB stick....I copied a pattern from the internet ...it seems to have read the pattern but when I put it in the sewing machine it comes up P1/P1
You downloaded a toyota dst file. The babylock will embroider the design but it wont display the design or any picture or attributes. It will sew it, but try on scrap fabric first to be sure.
Aug 12, 2013 | Baby Lock Sewing Machines
What causes the oil to leak?
1. Oil generally leaks because of mechanical failures.
To contain oils there needs to be a mechanical seal of some sort. This may be for the sake of argument a rubber ring or a flat strip or gasket seal of an appropriate material or even a propriety sealing agent which can be squeezed from a tube.
Simplistically a jar can be filled with oil and the lid which has a seal in it is placed on top secure enough to stop the contents leaking.
If that jar is connected to other jars by pipes to form a system they too need to have seals inserted where they join the jars so that there there are no leaks.
2. Seal failures can be caused by heat, chemical corrosion and or erosion , mechanical stress such as vibrations or bending or longevity of material properties such as the elasticity depreciating. Finally other causes can be attributed to wrongly fitted or inappropriate types of seals being fitted.
May 12, 2012 | Brother EF4N21 Sewing Machine
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
The needle does not move when the pedal is depressed, though the bobbin wheel and manual wheel do move, could this be attributed to a broken internal belt or?
Have you chosen a stitch pattern and a length, and made sure that the foot control plug is inserted correctely? Make sure your electrical outlet is good also. Good luck
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
I need to know how to thread my Viking Husqvarna Huskylock 905/910 This is a serger sewing machine and very difficult to thread. I have had this machine for quite a while and have not had the opportunity...
You have a great machine. These are hard to thread but once you have mastered it, you'll have many years of great use. The owner's manual has instructions, as well as the inside door of the machine (the door that folds down on the front bottom part of the machine. However, you might want to follow-up with your local authorized Husqvarna Viking dealer. Most are eager to help you even if you didn't purchase the machine from them. Some even have classes on using the serger. You might try several stores in the area. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
One fundamental tip is to follow the color coding, start with green, then blue/navy, then red, and finally yellow. The sequence is work inside to outside with threading (green - blue - red - yellow). Do not try different order--especially with green and blue -- since the threads build on each other. I have switched yellow and red with no impact but green then blue is always the proper order.
Good luck.
Jan 20, 2010 | Husqvarna Viking 1
My thread (not bobbin thread) is bunching excessively on my singer 7422 and can't figure out why.
Hi Tammy,
The problem seems to be with the thred tension adjustment lever/screw (it looks something like 2 inverted disc washers clamping each other thru which a section of your thred passes before going to the puller and then subsequently to the needle guide and then the needle. The fundamental principle of all sewing machins ae the same. Check for the tension. It may have become loose. Also check for the rocker on the inside where you place your bobbin. Are the rocker arriving in syncronisation when the needle is at its maximum in side the knotting hole. If not then there must have been a slight play in the assembly. You alone may not be able to solve all these things. But atleast you know what are the possibilities. I suggest you try only what you can do on the outside. As for the rest, you should refer it to an authorised service person.
Good luck tammy.
May 06, 2008 | Singer 7422
Sewing Machines Logo
71 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
