Question about Zebco 11 Authent Micro SpinCasting Reel 1Bb 4.3:1 4/75 11M-Cp
How do I get my reel to keep from letting the line out while I'm holding down the cast button?
When I press the cast button, it releases the line even when I'm still holding down the button, How do I get it to stop doing this?
    Habit-Forming:
  • 40 Answers
Hold the line with your index finger and against the rod itself. Then cast and release your hold
Posted on Jun 19, 2014
The line will not release when I cast
I am assuming you know at least something about fishing with a baitcast reel. If you do not, make sure you release the thumb button when you cast.
Chances are your line is either tangled or dirty on the inside. Also, the longer the line sits on the spool, the "curlier" it becomes, making it more difficult to get a good cast. I would suggest replacing your line.
If that doesn't help, then its possible that the release pin isn't releasing when the button is released. If this is the case, it is probably time for a new reel. Zebco 33's are inexpensive, and not really worth the trouble to try and repair- better to just invest in a new one.
Aug 08, 2014 | Zebco Spincast 33 Reel
When releasing the thumb control to cast the line drops free (making it unable to cast)
you have to release the button after you start your cast, distance,height and length of cast is determined by where you release the button inside the forward arc of your cast, just like throwing a baseball.
Oct 18, 2013 | Zebco 33 Authentic Spincast Reel, 1 Ball...
How do you cast the reel so the spool dosent continue to unwind after the cast
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Sep 21, 2010 | Penn 320GT2 Graphite Levelwind...
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
How do you cast?
flip the bail(the round rod in front of the reel)hold the line tight with your finger first and cast(make sure you let your finger off the line when you throw the rod forward.
Jul 17, 2009 | Shakespeare Agility Spinning Reel 6825
Wont cast
if u pushed the release button it will automatically lock if u real it wen u are finished casting make sure u put d catch bak on for the line to retrieve to ur reel
Mar 22, 2009 | Pinnacle Solene SLP10 Baitcast Reel
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Having problems casting
To cast the line, you hold down the A button, make a casting motion with your arm, and let go of the A button near the top of your casting arc. Reeling in the line is as simple as moving the Nunchuk in a circular motion or pressing the A button. You can move the line either left, right, or back by moving the Wii Remote in the same direction and increase or decrease the drag on the line by pressing up or down on the D pad on the remote.
check out this little girl playing the game....you can see the motions she makes to cast: http://www.youtube.com/watch?v=ozG-s2N2xmo
For more info on controls, gameplay and cheat codes, visit this webpage:
http://www.gamespot.com/wii/sports/rapalatournamentfishing/review.html
On the left of the screen, you'll see box art image, further under that you's see the 'get it at best buy' and further under you will see where you can click for images, videos, and hints & cheats. Have fun! :)
Sep 08, 2008 | Activision Rapala Tournament Fishing for...
Zebco 11 Authent Micro SpinCasting Reel 1Bb 4.3:1 4/75 11M-Cp Logo
132 people viewed this question
Top Zebco Fishing Experts
Jim Thurston
Thomas Perkins
Thomas Perkins
ray gallant
Are you a Zebco Fishing Expert? Answer questions, earn points and help others
