Question about Kodak EasyShare C663 Digital Camera
Same Even with brand new batteries it won't turn on. The little light comes on as thought it's going to, but then it doesn't.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
The camera has a CCD image sensor, it's not very power efficient - therefore it would have that kind of response if you're trying alkaline batteries (brand new or not).
Please try lithium batteries AA or CRV3. Or you can also try a fully charged Ni-mh batteries. It works all the time! (unless the camera is really in need of a repair - www.kodak.com/go/itg)
Posted on Aug 27, 2009
The battery is brand new and when hook it up and turn the key the neutral light and the hot light come on but when I hit the start button it clicks and doesn't click anymore. Not even turning over. Th
Remove battery terminals and clean both posts and terminals
with sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to current flow both into and out of the battery. Charge the battery as not all batteries are charged sufficiently when new to do the job. Also not all new batteries are good batteries as they suffer manufacturing faults which allow them to discharge internally. some batteries are sold without the acid so check that is not the case.. Check all terminal connections including any earth wires.
Jul 15, 2013 | ATVs
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
1994 Toyota Tacoma PreRunner - won't start with new battery, lights won't come on
Check your battery connections on the battery and the other ends where they go the ground will go to the engine block and the positive to a solenoid make sure all of this is tight and has no corrosion. This is just a loose wiring problem
Aug 18, 2012 | 2000 Toyota Tacoma PreRunner
Turned off my 2006 Escape & now it won't start.
battery failure ,it does happen,cleanbattery terminals pour boiling water over terminals if they are corroded loosen clamps by undoing nut wiggle clamps back and forthand and retighten if no lights then ,iwould suspect computor failure -------- youdoit.com
Jul 25, 2009 | 2005 Ford Escape
Notebook won't turn on or charge (new charger and new battery)
The New battery will not be charged yet, I wouldn't of thought, until you plug it in and charge it.
your problem is with the connector inside the Pc, that the charger connects to,
This has come lose and is now failing,
$150/$200 to repair the connection.
Regards
Richard.
Apr 22, 2009 | Sony VAIO XG39K PC Notebook
1997 stratus starting problems
This could the problem with battery getting drain even if your car is parked , this could the problem in the wiring or the grounding in the car ,first check if any lights or the cd player has the power even if the car is parked ............................
Good luck...
Nov 17, 2008 | 1997 Dodge Stratus
Kodak EasyShare C663 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
