Question about Whirlpool Washing Machines
Where can i gt a pedstal for a duet wfw94hexwo washer
    Sergeant:
  • 419 Answers
Try same store that you bought your appliances or contact manufacture or their web sites for dealer location on your area
Posted on Feb 03, 2015
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Can't find pump filter on whirlpool duet washer front loader modle wfw94hexwo
Don't know the specifics for your machine but the filter is almost always accessible via a flap at the bottom front or require the removal of the kick plate at the bottom.
Oct 24, 2015 | Whirlpool Washing Machines
Getting code F3 and not draining ??
The error code suggest a short circuit of the heater (In other words the hearet is worn out and needs a new one)> You can find a full list of duet error codes at: http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer dl light on but nothing happens when i press the cancel button or any button on the panel> i umplugged the machine thinking that it would reset but no change
'dl' on Whirlpool washers normally indicates there is a problem with the Door Lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. It will not reset. Sorry- Service call!
John C
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F1, does not stop filling, water pours out of soap tray
Are you sure it's not an F/H error?
The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
Get appliance parts at http://parts.fixitnow.com
Mar 13, 2011 | Washing Machines
My duet front load washer is saying that the controller is locked> What can I do to unlock it?
My dear friend this is an very common problem people do face with.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Nov 10, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Another F 11 Problem
Hello, Here is a link to a tec sheet whirlpool duet. gives you the other potential causes for the f11 error code and ways to diagnose what your problem is...Was very helpful to me when duet came out...Hope this helps...Mike http://www.affordableappliance.com/Download%20Folder/Whirlpool%20Duet%20Washer%20Service%20Manual.pdf
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
65 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
