Question about Archery
What year did he steal from the rich and give to the poor?
Rough idle, misses ,,Engine hesitates,poor acceleration
typically these problems are caused by either fuel problems or spark problems. I would pull the sparkplugs to see if the engine is running lean or rich. Normally the spark plugs should have a nice tan color to them. If they are wet or black engine is running rich. Easier still depending on the year of your Blazer, is to have the computer scanned for codes. Usually this will tell you exactly what is wrong.
Sep 09, 2016 | Chevrolet Blazer Cars & Trucks
What is something the poor have that the rich need and kills you if you eat it
NOTHING! Poor people have nothing. Rich people do not need anything because they have everything. If you eat nothing, you'll die.
Mar 17, 2015 | Cars & Trucks
Poor people have it rich people need it if you eat it you die what am i
Nothing.
Poor people have nothing. Rich people need nothing. If you eat nothing you die.
May 24, 2014 | Office Equipment & Supplies
Can a fuel pressure regulator give your engine to much gas if it's bad
Fuel pressure reading will give you the answer.but O2 sensor,engine temp,trottle position sensor,poor combustion like cylinder compression spark plugs, valve timing
As you can see there a lot of things that can change the rich and poor fuel metering.
hope it helps
Mar 25, 2014 | GMC K1500 Cars & Trucks
Running rich poor gas milage
carb or injection model year and other data would be helpful
Mar 15, 2014 | 1999 Dodge Neon
Is my muffin mix still good?
It should be good for up to 7 years, it depends how important you are in your own mind :) Some of the filthy rich demand only the best, the freshest. flour had to have been milled this week or toss it out... give it to the poor! :)
Dec 01, 2013 | Cameras
Poor acceleration and low gas mileage,smells rich at idle
You are off to a good start, MAF when it is contaminated it leans the vehicle out it doesnt make the car run rich, depending on the fuel strategy of the year make and model,and of course the engine size make all the difference,bad ignition coil make a car run rich shorted 02 sensor that lean bias make the car run rich, worn timing belt ****** timing and causes the car to run rich.so lets hear the results
Mar 24, 2012 | Cars & Trucks
1995 GMC JIMMY Runs rouph, P0306 stored rich condition, blck smoke out tailpipe
Prob needs a o2 sensor or oxygen sensor they are called
Sep 17, 2009 | 1995 GMC Jimmy
Rough Idle, Running rich.
Sounds like your automatic choke is giving you problems. Check to make sure the choke is operating correctly. If it ins not backing off as the engine gets to operating temp it will cause a rich condition and excessive black smoke out the tailpipe and extremely poor fuel mileage.
Feb 18, 2009 | 1984 Ford F 150
Archery Logo
167 people viewed this question
Top Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
