Question about Sony PlayStation 2 (PS2) Console
My dog knocked down my playstation 2 and now as hard as i can press the button i can't turn it on. is it jammed? what should i do?
  • 483 Answers
We need to open it and the on switch was maybe moved over somthin so poen it up and check if the sensor for the on/off switch is correctly placed in place.
ELSE
I believe your PS2 has a short circuit and needs another motherboard. If you can do this yourself, that’s great. You can find Motherboards or a PS2 like yours that will not read discs or has Disc Read Errors but will boot up for about $25 on Ebay. If you’re not comfortable with Changing out your motherboard, then click on the "Repair directory" at the bottom of this screen. On the Repair Directory Screen, select Video Game Consoles. Choose a good Repair shop.
Fame !
Posted on Jun 23, 2009
My sewing machine model is B 750 QE. Always starting to sew the lower thread keeps knotting up it drags down the fabric and the cogs come on the screen..So I looked at the instructions and followed the...
1. To solve your knotting problem. Learn to always trap or grasp your thread ends for the first few stitches.
2. When the dogs are down, sometimes you have to grasp and jiggle or turn the hand wheel while re-engaging the feed dogs.
3. It sounds to me as if you aren't making sure that the take up leaver is in the top position before you press the "foot button down" Make sure you press "needle up" before you press foot down. That way the dogs should be in the correct position for you to get the fabric under there and proceed. In the mean time... I would strongly recommend you go back to your dealer and take some lessons. It sounds to me that when you learned to sew... you were not trained the proper procedures.
Oct 01, 2013 | Bernina Sewing Machines
HOW TO RENEW MY HARD DISKS BUT IT WANT LET ME GO TO THE PLAYSTAION MENU
1 turn off playstation,disconnect controllers and remove memory cards
2 Hold power button down,system will turn on and off again
3Once system has shutdown press button again until you hear 2 beeps
4When you hear 2 beeps take oyur finger off button
5 Follow instructions after for controller hook up. Menu should be there.
Oct 09, 2011 | Sony Playstation 3 (PS3) Console
Can i replace ps3 hard drive with a laptop hard drive?
Hi, don't think so, their configuration, are not the same. there are not even the same size, nor with they fit in,not just possible..
If you have a hard drive problem, you could try the steps below...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
You can also get a replacement hard drive from sony ...
I wish you good luck
Please keep me posted,
Aug 11, 2011 | Sony Playstation 3 (PS3) Console
Hard disc is curropt and needs to be repaired but does not repair and will not allow navigation
How to Access Playstation Recovery Menu
2. Hold The power button down; The system will turn on and turn off once again.
5. You will be promted to plug in your controller via usb and then hit the PS button
have you tried options available in this menu?
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
Help my ps3 says the hard disk has to be formatted help i cant do nothing
use this procedure and you can reformat from there ok good luck
My playstation will not work, when i turn it on it says.. cannot start.. the correct hard disk was not found... was working fine last night.
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
Take care.
Sep 25, 2010 | Sony Playstation 3 (PS3) Console
The playstation hard disks file system is corrupted and will be restored.
well as cookies.
Take care.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Ps3 hard disc freezes
well as cookies.
Take care.
Jun 14, 2010 | Sony PlayStation Portable (PSP) Console
How do i clear the hard dive
You can also try the steps below:
Good luck.
Apr 05, 2010 | Sony Playstation 3 (PS3) Console
Recording button can't be pushed down any longer
1. PlayStation 2 systems do not handle tapes, but CDs and DVDs. No wonder you have broken it if you inserted a tape in it.
2. There is no radio in a PlayStation 2 system.
3. On a PlayStation 2 system, the button with a red dot on it is the power button, and it turns green when the power is on.
4. You cannot record, especially not on tapes, with a PlayStation 2 system.
5. You usually don't play a PlayStation 2 in the kitchen, but in the living room since it's meant to be plugged in your TV.
Here's the diagnostic : you do not own a PlayStation 2 system.
You have been ripped off by whoever sold you this piece of **** under the name of "PlayStation 2 system".
Jan 02, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
