Question about Ruud Heating & Cooling
What is the amp rating for a purple color air handler fuse?
    Genius:
  • Ruud Master
  • 1,363 Answers
If it is control board fuse it is 3 amp.
Posted on Aug 11, 2015
cactus bob
  • 267 Answers
SOURCE: fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Posted on Jan 24, 2009
  • 358 Answers
SOURCE: hi, I have an air handler motor made by GE
See where the purple wire is hooked up in the existing motor diagram (it could be the capacitor or a lower speed for the heater) and compared with the new one , and put it in the same place .But the easiest way to do it ,is to get the original replacement motor.
Posted on Sep 05, 2009
dmftrucker
  • 1922 Answers
SOURCE: lawn mower cut control cable going to outside
can you take an A.C. voltmeter and see if you have 24v.a.c at contactor on outside unit, if not recheck for same at control board inside to see if the same then you can start isolating the trouble
Posted on Sep 27, 2009
billyvangogh
  • 108 Answers
SOURCE: Goodman Air handler blowing fuse if switch outside unit not runni
Sounds like your compressor in your heat pump is siezed . You can try a "Hard Start" Capacitor...which basically gives your compressor a kickstart and works 95% of the time when compressors get older....It's hooked up in parallel with the existing Capacitor...if you're not familiar with Electrical etc I would call an expert and mention what I said . If this doesn't work you will likely need a new Compressor/Unit . You could also have a short to ground in the heat pump side....likely the compressor is the problem however the original Capacitor could also be the problem
Posted on Oct 27, 2009
SOURCE: I have a goodman ac
The low voltage wire to the out side is shorted somewhere or the contactor coil is burnt.Thats all it could be one or the other.
Posted on Jan 05, 2011
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
We have recently purchased a new home and the UBHK-25J21SFA air handler makes a whistling little tune and then the heat comes on. Never fails to work but noise is annoying.
Make sure the air is balanced... air handlers are rated @ a certain design static pressure. The static rating is on the air handler tag. Have someone measure that static. Too often hvac installers don't know much about airflow & they will undersize ductwork. Then again it could just be a dirty coil.
Nov 27, 2013 | Heating & Cooling
I was installing a new thermostat and in the process lost power to the thermostat. I crossed the red and green wires and the fan didn't turn on. I check the outside compressor and inside air handler and...
You can ck the low side of the transformer to see if you are getting 24v with a mutimeter. If you are then look on the cicuit board for a fuse. It would look like a fuse you would find under thr hood of your car. flat with two probes. Purple or pink in color.
Jan 14, 2011 | Heating & Cooling
Where is the fuse box in the inside air handler?
There should be a small 3 or 5 amp fuse on the circuit board inside the air handler.
Apr 19, 2009 | Heating & Cooling
Resettable fuse/breaker for TZ-4
The power to your zone panel is from the furnace or air handler. There is a 3 or 5 amp fuse on the circuit board inside the furnace or air handler. I hope this helps. Please don't forget to give me a Fixya rating.
Mar 13, 2009 | Honeywell Heating & Cooling
Fuse blowing on tappan air handler
Jan 24, 2009 | Heating & Cooling
Tstat wiring
What kind of system do you have? The fuse is usually located on the circuit board inside the furnace/air handler. It's probably a spade type and would be either amber or purple. 3 or 5 amps.
Jan 22, 2009 | Goodman CLJ30AR32 Air Conditioner
Central A/C will not turn on
There is usually a small fuse inside the indoor unit(furnace or air handler). That fuse generally is located on a circuit board and looks like a car fuse. It may be amber or purple in color. This fuse may have blown. If so you may have a bad circuit board. I recommend calling a NATE certified Tech for service as this one has several possibilities. Good luck.
Jan 17, 2009 | Heating & Cooling
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
