Question about Troy-Bilt TB146 EC 4-Cycle Garden Cultivator
Stops after it runs a short time - Troy-Bilt TB146 EC 4-Cycle Garden Cultivator
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
Car starts after short time runing stops after a while stars againe runs againe and stops againe
Faulty fuel pump, pump relay, wiring, connections. Could be a temperature sensitive crankshaft sensor going open circuit when hot and functioning again after a short time.
Could be many things...
Dec 06, 2015 | 1993 Saturn SL1
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Starts running for short time then stops
Sounds like the compressor has fused windings. The only way is to get it checked by a refrigeration technician. It may only be a start relay.
Regs,
Hawk
Jan 16, 2010 | Engel Refrigerators
Fridge cools short time and stops
sounds like the condensor fan isnt running. I would replace the fan if thats the case. If the fan is running then you have a overload problem or a bad compressor
Aug 02, 2009 | Refrigerators
Chain saw run s for a short time and stops
The engine is unable to draw adequate fuel from the tank on a continuous basis, the filter may be clogged or there is an air leak in the fuel line between the fuel tank and the carburetor.
May 26, 2009 | Poulan Garden
Short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Aug 25, 2008 | Fellowes DM15C Shredder
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Jul 22, 2008 | Heating & Cooling
Water pump turns on and runs for a short time than stops for a short time then starts and then stops. And the machine can not spin because the water is not out enough.
Check the pulley, the belt(s) that turns the pulley and water pump, and check the water pump itself. Also, check for debris in the hose from the tub to the water pump,
Jun 18, 2008 | Hotpoint Washing Machines
Troy-Bilt TB146 EC 4-Cycle Garden Cultivator Logo
80 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
