Question about Baby Lock Sewing Machines
How do I oil my baby lock grace? - Baby Lock Sewing Machines
Baby lock quilt & craft model BL2300K. I received this from mother in law, no manual. Does any one know where the oil locations are so I can oil. Starting to make noise needs oil, thank you, robert
As a computerized machine, it is probable that there is very little (if any) oiling required. You can check with your local Baby Lock dealer's technician for oiling instructions and a manual for your machine. (Oiling incorrectly could permanently damage the machine.)
I was unable to locate a manual for your machine, but did find this web site:
Baby Lock Manuals
Dec 22, 2016 | Baby Lock Sewing Machines
Do I oil my baby lock esante
A lot of newer computerized machines do not require oiling. Oiling improperly could damage the machine. You should probably contact a Baby Lock technician before attempting to oil your machine.
Jul 20, 2016 | Baby Lock Esante
How and where to oil my baby lock sewing machine?
Difficult to advise without a model number.
The owner's manual should have cleaning and oiling instructions (maintenance section).
If that doesn't help, you may want to contact Baby Lock support or a dealer for advice.
Jul 21, 2015 | Baby Lock Sewing Machines
Where to oil ellegante 2 baby lock machine?
NO WHERE. It is oil impregnated.
Only a repair tech should Lubricate, never oil this type of machine.
What is an error 5 on baby lock Grace
try adjusting the top thread tension
also try changing the needle-one that is for the fabric and thread
if that doesn't help, then a repair shop would be a good idea
Apr 05, 2014 | Baby Lock Sewing Machines
Baby lock/grace model is stuck on E8. what do i do?
it sounds like it's time to have the machine serviced, it's
possible that something is wrong with the motherboard.
Feb 09, 2013 | Baby Lock Sewing Machines
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 02, 2012 | Baby Lock Eclipse Serger
Do i need to oil my baby lock sewing machine?? Quiter's choice.
I cannot find a manual for this machine except at sew4less.com and the price is $14.95.
Contact Babylock to see if they will provide you with a download of the manual - http://www.babylock.com/contact-us/index.asp
If this is a mechanical machine, use sewing machine oil and the shuttle may be the only place it will need to be oil.
Apr 30, 2010 | Baby Lock BL1556
My Baby Lock Serger model BLE1AT oiling
Baby Lock.com says you have to take it in to a dealer, as oiling requires removal of covers that would void the warranty.
Dec 30, 2009 | Baby Lock Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
