Question about Soleus Heating & Cooling
How to take unit apart for cleaning
The coils and vents are filthy and needs cleaning
2 Suggested Answers
  • 94 Answers
SOURCE: I have an Armstrong COncept
Dont worry about removing grill just make sure unit is unplugged.
Posted on Apr 30, 2011
How to clean inside Coils for Rheem model # RRKA-A036JK08E
There is a product called "Coil Brite" That is designed to clean coils. It is a spray on liquid that will dissolve the crud built up on the coils.
Aug 27, 2014 | Heating & Cooling
Maytag ldg7500aaw gas dryer. I have replaced the coils, checked the flame sensor and the other sensor on the flame tube. It still ignites then goes off.
How long does the flame stay on? Burner parts, you may have a air flow issue, disconnect the vent from the back of the unit. run the unit. If the unit runs better, the issue is not in the dryer. If while disconnected the unit fail to still run, the problem is internal and will need to be taken apart to clean out the vent system in the door area.
Good Luck
Oct 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a tempstar central heat and air unit and i need a wire diagram for a model pa5548aka4.
my tempstar central a/c unit will not get above 80 degrees during the day, the charge is fine so we are told, we noticed that the coils and fins are filthy and we have done everything to try to clean it out with a fin tool, fin brush and coil spray and there is still junk in it. we cannot remove it and clean it outside as i would love to do; its too involved to do that so we are trying to clean it in its place we have also sprayed it with a water hose and an air compressor, although it helped some i can still see gunk in it. my coils are on the bottom end of my inside unit. any advice on what else can be done to clean it well? my unit is only 7 years old. also i was told that i need to set my blower to high speed how do i do this and where is it located? thanks for any help or advice. my e-mail is map41269@yahoo.com
Oct 06, 2010 | Heating & Cooling
Freezer not cold enough...I tried cleaning vent for fan because it was filthy...I had a feeling the compressor was overheating....touched compressor, hot to touch....freezer started to get progressively...
sound like the gas has escaped so may be cheaper to buy a new one as the radiator on the back should be hot exchanging the heat from the freezer to the radiator & cooling the freezer!
hope this helps, but I say buy a new one as you could have other problems & end up spending more money !
Sep 22, 2009 | Refrigerators
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Freezor is no longer freezing the food.
take a look underneith the unit to see if the condenser coils is filthy, that could be the problem right there. if its clean then is there any ice built up on the freezer coil? or is the drain line clogged up and causing the unit to freeze up? take a look at these and if your unit isn't running then get ahold of me and we can go over other things.
Feb 18, 2009 | Whirlpool Refrigerators
Power lose
I have a 45 pint. I have to slide the bucket in and out of the unit multiple times. Make sure to wait a few seconds after each time to see if it will recognize no water (sometimes the red light comes on, but then changes it mind). Also, I've found that leaving the bucket a little crooked will make it respond. It sucks, I know. Mine is only a year old too. Should not be a problem like this!
Sep 14, 2007 | Frigidaire FDL45P1 Dehumidifier
Heating & Cooling Logo
26 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
