Question about Maxell DAT 72 Storage Media Single
Maxell DAT write protect
Why would cartridge get write protect error
Stable lift jacks
I think you need to review this - I thik you have trouble if you are trying a 30 amp cord into a 4mm DDS DAT Tape.
Dec 05, 2013 | Maxell Products - 1/8 DDS-1 Cartridge 90m...
Maxell DVD+R is saying write protected when I try to format it. How do I remove writte protection on it?
Due to the differences in the way DVD +r and DVD -r work, I have found the first thing to fail as a laser ages is DVD +r. I have not discovered why as they both burn discs, similar way. It may have to do with the different chemical composition of the disc or the burn alignment method used (every disc is gauged for its 'best' burn setting by the drive)
Apr 24, 2010 | Maxell - DVD-R - 1 x 120min (567613) Media
I need to find a Digital Audio Tape (DAT) deck to play Maxell R-124DA and TDK DA-R180 tapes. DAT tape decks are no longer manufactured. The tapes contain voice and limited music and number between 100 and...
Dat equipment is readily available on Ebay and at sometimes unbelievable prices. Wouldn't you think manufacturers would stick to a format and stop inventing new ones just to sell more units and making perfectly good equipment useless. Pawn shops is a good place to find unused hifi gear also.
I just did a quickie search of The US Eby site and there are 1471 entries for DAT storage and player units. Some as low as $10 and dat tapes as low as a cent. Take a look, if Ebay scares you I can assure you there are more ripoffs happening in retail stores than on Ebay. I've been merrily saving a fortune on all types of equipment ever since it arrived in Australia. Buy the gear for next to nothing and do the work yourself, at least you'll know it's been done properly. There's even units which mount straight into your computer. DAT machine, editor and CD machine all in one. I might do like wise. I have a large collection of DAT tapes I picked up at an auction. HMMMMmmmmm.
Apr 23, 2010 | Audio Players & Recorders
Write protected error
IN THAT FLASH DRIVE JUST CHECK FOR ANY SYMBOL DAT A LOCK MARK AND MAKE SURE THAT IT UNLOCKD BEFORE U PUT IT INTO YOUR COMPUTER
Apr 16, 2010 | Electronics - Others
I have a Maxell 8 gb, S880102A. which suddenly
Here's how I fixed it:
open Regedit and navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrrentControlSet\Control\StroageDevicePolicies
If there is a WriteProtect key (REG_DWORD) then
1 = Write Protect On
0 = Write Protect Off
Mar 08, 2010 | Electronics - Others
My pen drive was write protected by DPROTECT.DAT
Not sure what you want to do. If you want to use it and there is nothing important in the thumb drive, you can go Format by right clicking on the thumb drive and pressing format. This way you can start fresh with it.
Dec 08, 2009 | Computers & Internet
Red lights flashing
The term to google is waste pad counter or protection counter, there are loads of sites and discussions on the subject. what has likely happened is the charging of the new ink cartridges has pushed the counter over the brink.
Jun 05, 2009 | Epson Stylus Photo R200 InkJet Printer
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Maxell DAT 72 Storage Media Single Logo
26 people viewed this question
Top Maxell Electronics - Others Experts
 Grubhead
Grubhead
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
