Question about Soundstream RUB1.700 700 watt 1 channel rubicon amp
What size fuse do i use in my amp
Need to know proper size fuses to use
  • Soundstream Master
  • 3,368 Answers
I would highly replacing it with an identical one.
What is the question? More information is needed before somebody can help you.
Posted on Nov 04, 2014
I need to know what type fuses i need for the turn signals
For your vehicle it should carry either ATO or Mini type fuses, if in doubt, take out the fuse from your car and take it to the auto parts store, as they can help you find the right fuse type and amps.
if you are not sure of the fuse amperage, buy the multi pack, which will have fuses with variety of amps, keep in mind the type, size and shape should be same.
Most if not all, automotive fuses are 12 Volts fuses.
The repair manual, Car owner's manual, the dealership can help you find out the fuse specs,and fuse box location(s) for your car.
A fuse puller or needle nose plier is helpful for servicing of the fuse.
ATO type fuse looks shaped same as the mini fuse, but larger in physical size.
MINI type fuse shaped same as the ATO fuse, but smaller in physical size.
Your vehicle may have a defective Fuse,Relay,Bulb, Bulb Connector, that is causing the malfunction.
Also check for bad connections, but don't forget to check the switch assembly, check for dust and spray it out with can of compressed air, found at computer shops.
Apply electrical grease to help keep moisture out and keep it working properly for long time trouble free.
Have a nice day.
May 07, 2016 | 1997 EIGHTY EIGHT A/C Compressor a1z28173
I need to know what size fuses go where?
jsut put 15 amp everywhere,should be enough but to large to cause any problems.
Jan 05, 2012 | 1991 Dodge Dakota
Need to know what order to hook up red,yellow,and black wire which to positive which to neg and what size inline fuse is needed for my mcd 5080
Red- power Yellow-Memory Black-Ground
Unless the yellow wire has a fuse built into it then....
Yellow- Power Red-Acc/Ign Black- Ground
If the fuse you are asking about is on the radio t s usually a 10 or 15 amp fuse but if you mean for the power wire for a amp then it depends on the power amount of the amp....look on the amp and find the sum of the fuses on the amp and use a inline fuse that is the next fuse size sum...
Ex. 2 40 watt fuses on the amp then 40+40=80 watts so you would want to get a 100 watt fuse. Also remember you can never go to big for your inline fuse with a amp
Aug 22, 2011 | Jensen Car Audio & Video
What is the fuse size ( I know voltages but not proper ampage) for thr Harman/Kardon hk 695? Thank you
Greetings - You need a Radio Shack 270-1062 3/4 amp slow blow fuse or equivalent. Any .75-1 amp fuse of the same size should work fine.
Regards and Good Luck.
Thanks for using Fix Ya.
Mikeywaf
May 01, 2011 | Harman Kardon HK695 Computer Speakers
How do i know what size fuse i need for a hitron hra 2500 amp?
im assuming you dont have the old one. typically it will be 20-50a. i recomend consulting the manufactures website.
Apr 25, 2009 | Hitron HRA-2500 250W 2CH Amplifier Car...
Size of fuse for Ultimate PA2204
O SO U JUS NEED LIKE A FUSE THAT IS ABOUT 20-40 AMPS
Mar 20, 2009 | Car Audio & Video
12v wire
hello . what has happen is one of a couple of thing .? the wire could be burnt becouse of to menny amp's going throught it . becouse it's fuse is to big for the size of the wire. that you are using for your hot wire.to run your amp.!!! it work like this !!! the wire is gaged buy it's size .!!! and that determine's what size of fuse that could be used .!!! for that gage of wire.!!! in amp's.!!! that it let flow through it.!!! and a fuse is determin in it size in amp.!!' it will let flow through it the fuse. !!! and most likly you or someone has put to big of a fuse in .!!! you inline fuse holder .!!! that run's from the + hot of the battery all the way to your + side of your amp's.!!! that's mostlikly where you will find your problem.!!! check it first.!!! ok .!!! then check your amp it should have a fuse that plug's in to it .!! on the side of the amp.!!! you need to make sure that you use the right size of fuse for that gage of wire.!!! if you use to big of fuse you will have a wire fire or a melt down that burn's the wire in half or worst.!!! hope this help's you let me know. "GOOD LUCK"
Aug 03, 2008 | Car Audio & Video
Car alarm in-line fuse
What type of alarm system is it? The size of the fuse varies slightly depending how extravagant the alarm is. You could try to low ball it and if it pops the fuse then get a slightly bigger one. You might start out at 15 amps. BUT, if you can tell me the make and model of the alarm then I might find out the correct size. I hope I can help.
-Andrew Hawkins
Mar 31, 2008 | Car Audio & Video
Blown fuses
I used to have one of those amps also (nice amp btw) Did you try another fuse of the same size?
Is it blowing fuses everytime you put one in or did it just blow that one fuse ?
Is the conection on the battery solid and clean of corrosion build up? Because that is a good amp and if wired properly shouldnt blow out or anything and so if the speaker is not blown then maybe connection is weak somewhere? I would try disconnecting the speakers from it and try a new fuse and if it does not blow the new fuse than amp is ok? and if it does blow the new fuse right away then there must be a short somewhere in the wire or the amp. then disconnect the fuse again and reconnect the speakers and if the fuse blows with the speakers connected but doesnt blow with them disconnected then you know it is a blown speaker causing the problem.
Just currious but what size fuse do you have connected at the battery?
Jan 06, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Soundstream RUB1.700 700 watt 1 channel rubicon amp Logo
Top Soundstream Audio Players & Recorders Experts
richie46
Gil Shultz
Lawrence Oravetz
Are you a Soundstream Audio Player and Recorder Expert? Answer questions, earn points and help others
