Question about Polaris 800 Twin Sportsman Ride on Toy
The switch has reversed on my grandsons 800 twin. it is in reverse all the time, and he has to pull back on the shifter to go foeward. what is up with that?
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch.
The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.html
Replacing the shifter should get your Power Wheels running correctly.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 26, 2013 | Fisher Price Power Wheels Barbie Mustang...
Sons polaris 800 twin sportsman two seater 24 volt was riding fine in all gears and now he can only go in reverse
this could either be the that one of the motors has died or the connecter on the bottom of the shifter switch has come disconnected, i'd probably check the shifter switch first, you'll have to take out the battery and then the black plastic panel by the battery this will give you access to where the shiter assembly is and then underneath the four wheeler you'll have to remove the two screws that hold the shifter assembly in and then verify that the two plugs are plugged into the bottom of the shifter assembley
Apr 21, 2012 | Polaris 800 Twin Sportsman Ride on Toy
Peg Perego Polaris Sportsman 600 ATV the reverse does not work. the 1st and 2nd drive work but when placed in reverse it still goes forward. I do not have a user manual would anyone have any answers
remove the battery and black plastic panel and this will give you access to shifter switch, please verify that all of the connecters are connected to the bottom of the shifter switch
Sep 02, 2011 | Polaris 800 Twin Sportsman Ride on Toy
Quad only will move in reverse wont go forward it was working and then forward quit it and the battery is fully charged is a wiring diagram available
remove the battery and the black plasctic piece this will give you access to the shifter switch, verify that the connecters on the bottom of the shifter witch are still connected
May 23, 2011 | Polaris 800 Twin Sportsman Ride on Toy
Our polaris 4 wheeler will not go forward only reverse. How do we fix this problem?
rmove the battery and black plastic piece under the seat, this will give you access to the shifter switch, make sure that both of the connectors are connected
Jul 04, 2010 | Polaris 800 Twin Sportsman Ride on Toy
No forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Jul 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Unit will not go forward but goes into reverse and runs
remove the battery and the black plastic piece this will give you access to the shifter switch, check the bottom to make sure that both of the connecters are securily fastened
Jun 21, 2010 | Polaris 800 Twin Sportsman Ride on Toy
When i put my truck into reverse my lights dont work however if i pull my shifter back inbetween reverse and neutral if i get this one spot they come on
There is usually a switch mounted on the transmission. Perhaps it has gotten loose or something is worn or broken. Your gear selection goes park, reverse, neutral and drive. Since the switch is not coming on from park to reverse but it kinda does if you go past reverse (neutral) then it sounds like the switch has moved from its original place. That's why I think it is loose. Good Luck!
Mar 15, 2010 | 1998 Jeep Cherokee 4WD
I have a 98 jeep cherokee 4L 4x4 automatic and the reverse lights dont work the bulbs are good and all fuses are too? any ideas
Reverse lamp switch wiring or switch itself is defective. Mounted on trans. Run slector lever over reverse with someone watching. the back.If yhey flicker the switch is bad. Work it several times sometimes helps .
Oct 28, 2009 | 1998 Jeep Cherokee
Polaris 800 Twin Sportsman Ride on Toy Logo
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
