Kodak 750H fix - Office Equipment & Supplies
    President:
  • 412 Answers
Tell us specifically what the problem is, and we will take a shot at a solution for you !!!
Posted on Dec 09, 2014
5 Suggested Answers
  • 412 Answers
SOURCE: model 750H overheated and guide says
That is correct. There are 2 thermal fuses: 1 near the lamp, 1 on the power motor. This repair should be made by a factory-trained tech.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: Kodak 750H and 760H neither will advance carolsel without manual
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
  • 412 Answers
This is a common problem with older projectors like this. There is a "link" that connects the slide cycle solenoid to the slide change mechanism. The "link" is plastic and gets brittle & cracks with age, rendering cycling non-functional. this is a difficult repair, but parts are still available. I recommend you contact an factory-trained repair dealer to get your projectors repaired.
Posted on Nov 21, 2010
  • 412 Answers
SOURCE: kodak carousel 750H will advance, but the slide drops down and then pops right back up so you don't get a chance to see the picture. Any ideas on how to fix this?
You are experiencing a condition called "continuous cycle". This is usually caused by excessive wear. To attempt a fix, unplug the projector from the power source. Turn the projector upside down & remove the 4 screws & elevation foot that secure the bottom cover in place. Near the center of the slide change mechanism is the clutch contacts (look for the hub at the end of the camstack). One is a straight, small diameter wire protruding out of the hub. The other is a "L"-shaped wire (the same diameter) that SHOULD capture the straight wire. The wire is captured and the cycle is complete. What has happened is one of those 2 contacts has worn, allowing camstack to constantly rotate, causing a continuous cycle. You must GENTLY re-form one or both of those contacts just enough so that the straight contact is captured by the "L"-shaped contact at the end of the cycle. Good luck !!
Posted on Oct 26, 2012
Want to buy a kodak 750H power cord
Check for the power cord at: www.micro-tools.com
They bought the entire Kodak service parts inventory about 10 years ago.
Good Luck!! Jim
Jul 20, 2015 | Kodak Office Equipment & Supplies
Kodak 750h won't reverse
If the projector cycles in FORWARD and holds SELECT when the SELECT button is pushed and held, then the projector simply needs a cycle solenoid adjustment. This can be accomplished by following the adjustment procedure in the Kodak Service Manual posted at: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
Good Luck !! Jim
Apr 17, 2014 | Kodak Office Equipment & Supplies
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
Kodak carousel 750H will advance, but the slide drops down and then pops right back up so you don't get a chance to see the picture. Any ideas on how to fix this?
Oct 07, 2012 | Kodak Office Equipment & Supplies
I have a 750H Kodak slide projector. Where do I find a bulb for it?
The KODAK Carousel 750H uses a 300 watt, 120volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 19, 2010 | Kodak Office Equipment & Supplies
Focus Lense Will Not move using the remote or the dial - What can I do? Kodak Carosel model 750H
The KODAK Carousel 750H was manufactured from roughly 1971 to 1981.
If you can push the focus knob toward the outside of the projector and manually remove the lens, then the problem is the gear on the focus shaft (the shaft the focus knob turns). The gear has either cracked and fallen off or is cracked and slipping on the shaft. Either way, the focus shaft needs to be replaced by a factory-trained repair technician.
Jul 08, 2010 | Kodak Carousel 4400 Slide Projector
May 12, 2010 | Office Equipment & Supplies
Mar 20, 2010 | Kodak Office Equipment & Supplies
My Kodak Carousel 750H slide projector will not drop a slide down into the projection chamber.
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Oct 18, 2009 | Kodak Office Equipment & Supplies
Model 750H overheated and guide says
Sep 17, 2009 | Office Equipment & Supplies
jasbo
jasbo
