Question about Daiwa Sport & Outdoor - Others
Cleaning the drag on a m1 mooching reel - Daiwa Sport & Outdoor - Others
2 Suggested Answers
  • 98 Answers
SOURCE: reels on reel to reel
sounds like a loose drive belt. replace it. or a bad tape try another brand.
Posted on Feb 28, 2010
Setting the drag on a model Crossfire 2500 daiwa spinning reel
Hi
To set the drag on the spinning reel you adjust the knob that holds the reel in place. The same knob you use to take the reel off to clean and oil. It will hold the reel in place and as you thighten it down it will increase the drag.
May 10, 2017 | Fishing
How do you set the drag on a model Crossfire 2500
Hi
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
How can I set the drag on a shimano R 2000 spinning reel
The letter "R" on a Shimano reel typically indicates it has a rear drag.
you should find a know on the bottom end of your reel that allows you to adjust drag tension. Just Remember to back off or loosen your drag when not using your reel to keep your drag in proper working condition.
Dec 06, 2014 | Fishing
Snarled line on low profile reel.
readjust your drag and use your thumb more when casting . free spool reels still need casters help
Apr 25, 2010 | Shimano REELS TYR20 Tyrnos Lever Drag...
Drag automatically tightens as line is pulled from spool
Clean and grease the reel. Make sure all washers that belong on inside are installed properly
Oct 31, 2009 | Penn Spinfisher 950SSm Saltwater Spinning...
Require a diagram to assemble 330GTI reel. Reel disassembled as drag not functioning properly
Here you go!
330 GTi Schematic
Make sure the drag plates and drag washers go in correctly or the drag will not work very well.
If you are using braided superline, make sure there is monofilament backing under the line otherwise the braided line will slip on the spool arbor, tricking you into thinking the drag is shot.
Best of luck!
Mike
Sep 26, 2009 | Penn Gt Levelwind Series Reels
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
Sport & Outdoor - Others Logo
24 people viewed this question
Top Daiwa Sport & Outdoor - Others Experts
Andrew Taylor
Andrew Taylor
ray gallant
Robert Larose
Are you a Daiwa Sport and Outdoor - Other Expert? Answer questions, earn points and help others
