Question about Minolta DiALTA Di250 All-In-One Laser Printer
Reset imaging unit on minolta copier - Minolta DiALTA Di250 All-In-One Laser Printer
  • Minolta Master
  • 6,680 Answers
Can be reset but requires a fuse. And will require taking the bottom cover off the Image unit cartridge! SEE THE MACHINE WILL BLOW THIS FUSE INTENALLY TO VERIFY THAT THE IMAGE UNIT IS NEW :)
Posted on Dec 29, 2014
2 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: I replaced the drum unit
You can not just reset the drum counter. When you reset the counter then the ATDC reference value is also reset. This will throw off the developer to toner ratio and your copies will usually become light or overtoned. The developer is supposed to be replaced at the same time the drum is replaced. The drum count is then reset and the F8 function in the service mode is run to calibrate the new developer. If you do not perform this procedure in the right order and correctly you will end up with at best poor copy quality. I would recommend calling a service person out to change the developer and then reset the counter and do the F8 procedure.
Good Luck and Thank You for using Fixya.
Posted on Feb 03, 2011
Testimonial: "Thank you. I do have one more question. The service manual for this model gives me a different order of procedures than yours. Which should i follow?"
How to reset Konica Minolta bizhub c203 colour copier c-2558 error
Black image unit, Is the black image unit OEM or third party? Remove the unit and replace. is the Toner OEM? or third party? remove and replace with OEM parts. Open close front door to reset code. If comes back get a tech out to look at could be a bad Sensor.
Nov 06, 2015 | Konica Minolta Office Equipment & Supplies
Reset imaging unit of Minolta MagiColor 2210
when you replace the image unit for what ever color is the machine asking for
Feb 11, 2014 | Konica Minolta Minolta MagiColor 2210...
Error c2652 in konica minolta c250
C - 2651 Cyan imaging unit EEPROM acces error
C - 2652 Magenta imaging unit EEPROM acces error
C - 2653 Yellow imaging unit EEPROM acces error
C - 2654 Black imaging unit EEPROM acces error.
Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit.
Try reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble resest message is displayed.
Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Apr 16, 2013 | Konica Minolta bizhub C250 All-In-One...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Where can i find,please, Minolta bizhub c550 imaging unit chip reseter?
Imaging unit reset automaticaly if a new is in copier.If you enter in the service mode you have a posibility to change the image unit life duration standard to long life.
Jan 24, 2013 | Konica Minolta Bizhub C550
The imaging unit needs to be changed
This needs to be done by a trained technician but if you can get the imaging unit from a minolta dealer you may be able to do it. Just remember that you need access to the service manual to reset the imaging unit counter after replacing the unit. Good luck.
Sep 29, 2012 | Konica Minolta DiALTA Di200 Copier
Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Sep 13, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Mar 10, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta DiALTA Di250 All-In-One Laser Printer Logo
61 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
