Question about Archery
What year did Robin Hood steal from the rich and give to the poor?
Robin Hood bicycle serial #6292WG when/where made
If it's a 3 speed just look on the hub, which has month and date of manufacture. For more info see my tip:
How to determine the year value etc of your bicycle
Jun 08, 2017 | Cycling
I have discovered a raleigh 'robin hood' [it's badged robin hood] ser. no 16974 with rh underneath. Any clues please?
Best indicator is the date of the Sturmey Archer hub - shows year and month of manufacture. Link below will give you some more info, as will a simple Google search for Robin hood bike.
Determining the Age of Raleigh
Nov 23, 2016 | Cycling
Can a fuel pressure regulator give your engine to much gas if it's bad
Fuel pressure reading will give you the answer.but O2 sensor,engine temp,trottle position sensor,poor combustion like cylinder compression spark plugs, valve timing
As you can see there a lot of things that can change the rich and poor fuel metering.
hope it helps
Mar 25, 2014 | GMC K1500 Cars & Trucks
Is my muffin mix still good?
It should be good for up to 7 years, it depends how important you are in your own mind :) Some of the filthy rich demand only the best, the freshest. flour had to have been milled this week or toss it out... give it to the poor! :)
Dec 01, 2013 | Cameras
Why is Robin Hood trophy so expensive?
The Robin Hood trophy is so expensive because the first arrow is completely destroyed and the second arrow is also damaged and unsafe to use. And when a single arrow cost at least 30 dollars in can get really expensive.
Aug 26, 2012 | Betsey Johnson Archery
What a Robin Hood?
Robin Hood is when one arrow strikes the back of another arrow already embedded in the target.
Poor acceleration and low gas mileage,smells rich at idle
You are off to a good start, MAF when it is contaminated it leans the vehicle out it doesnt make the car run rich, depending on the fuel strategy of the year make and model,and of course the engine size make all the difference,bad ignition coil make a car run rich shorted 02 sensor that lean bias make the car run rich, worn timing belt ****** timing and causes the car to run rich.so lets hear the results
Mar 24, 2012 | Cars & Trucks
Cheats
sure
while playing:
press enter and type
robin hood gives u 1000 Gold
Rock on gives you 1000 stone
Lumberjack Gives u 1000 Wood
press H the enter and type how do you turn this on gives u war cars
thats all what i remeber
rate plz
Feb 26, 2009 | Microsoft Age of Empires 2: Age of Kings...
Archery Logo
150 people viewed this question
Top Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Don A
Don A
Are you an Archery Expert? Answer questions, earn points and help others
