Question about LG Electronic Window Air Conditioner
Why do ac outlets stop working - LG Electronic Window Air Conditioner
Why won't it take a charge from AC outlet
Want to charge the battery from there the charger goes directly on the battery those little wire from the ac outlet are gonna frye
Mar 15, 2015 | Vehicle Parts & Accessories
Hitachi AC stops working after Red Light glows
No model number, no error codes!
check the obvious like is condensate water getting released, is anything blocked including any filters, the inlet, the outlet, or any hoses. Is power OK.
May 19, 2014 | Heating & Cooling
Mr coffee model gbx23 stopped working, it won't turn on.
It might be a problem with your outlet, and not the coffee maker. Your kitchen outlets should be GFCI protected. There is supposed to be a sticker on all outlets that are protected by a Ground Fault Circuit Interrupter, but sometimes they are left off. Look for an outlet in the kitchen that has a rest button between the outlets. You can also take the coffee maker to a known working outlet, or bring something that you know works to the coffee maker outlet, to see if it is the outlet that is not working or if the coffee maker is still not working at a good outlet. If the outlet isn't working, try others in the kitchen to see if they are. If they are not, and you didn't locate a reset button on one of them, then check the breaker box for a tripped breaker.
Coffee makers do have at least 2 safety switches inside them, but they are only to keep them from overheating and catching fire. If one of the switches did go bad it is possible that it might shut down the entire machine. If that is the case, then it's time for a new coffee maker, as the safety switches are not servicable.
dd1bd15d-8ff7-4198-9167-3cc45a5562ef.jpg120v AC GFCI outlets
(220v AC outlets will have the same reset buttons)
Apr 28, 2014 | Mr. Coffee GBX23
My Wii stopped working. Nothing lights up.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
My airconditoner window AC suddenly stopped working.. I had checked the power supply also, with the remote also its not working..plz help
Not much you can do unless you can do. Did you checked the outlet. Was the AC unit powereed up so the remote would work
Aug 20, 2009 | Heating & Cooling
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
Our Syvania tv just stopped working. No sound, nothing. We checked the elctrical cords, and remote etc. It will not turn or click on at all.
You may have a blown fuse inside the TV. Also make sure your AC outlet is working by plugging in another lamp to the same outlet.
If your outlet is ok, your TV needs service and repair.
Feb 24, 2008 | Televison & Video
LG Electronic Window Air Conditioner Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
