Question about Generac 2700 Psi Pressure Washer
My generac was running fine then just dropped to idle no pressure
Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
Nov 28, 2013 | Generac Power Systems Generac 5522 14 Kw...
Generac 6hp pressure washer starts and runs fine, no real leaks, but it never builds up pressure.
after making the water connections, be sure to hold the trigger open on the wand for a couple of minutes before starting. All the air must be removed from the system before it can create pressure.
Aug 28, 2013 | Briggs & Stratton Pressure Washer...
Need adjustment procedure for a Generac Centurion generator, carb and regulator under full load
Before you adjust anything, suggest you verify gas line for proper pressure and importantly volume. Pressure for gas should be 5 to 7 inches and propane 11 to 14 inches W.C. Also make sure the line to the generator is sized properly and the gas meter is a high volume unit (if NG). 90% we find the problem with generator sunder load that otherwise are fine are fuel related. Good luck.
Sep 19, 2012 | Generac Power Systems Centurion by 16000...
Hello, I installed my 10 kw #5871 guardian yesterday 2/24/11. The propane pressure was checked at all loads and never dropped. It is set at the manuals recommendation. At mid to full load it runs smooth...
I had to find out through a Generac Service Tech that the Idle screw needs to be turned down so it doesnt surge. I found this out after a surge blew $400 worth of electronics out in my home. I have a surge protector now I recommend you do the same. DG
Feb 25, 2011 | Guardian Electrical Supplies
Generac 4000xl high idle, idle control not working.
check to see if somthing is blocking the movement of the govenor linkage
Oct 26, 2009 | Electrical Supplies
Generac Watchdog 15K, engine will not start
throttle motor or governer board. or control board. your gas line could be to small. check the pressure while its cranking to see if it drops. watch the throttle to see if its moving while trying to crank the generator
Jun 27, 2009 | Generac Guardian 200 Amp Transfer Switch...
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Generac 2700 Psi Pressure Washer Logo
Top Generac Garden Experts
Arnie Burke
Arnie Burke
Tom Chichester
jeff chenault
jeff chenault
Are you a Generac Garden Expert? Answer questions, earn points and help others
