Question about Saws
Rexon bandsaw 12inch variable speed
Blade keeps coming off appears the bottom wheel has worn on the axle can I get replacements ?
5 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: bandsaw blade keeps coming off Rexon BS 10
Unplug the saw and take the covers off the wheels. See if any of them show excessive end play or deflections when gently racking them from side to side. You may need to shim the wheels. Ideally, you want them all to track in the same plane, and you can check this with a straightedge.
There should be a tracking thumbscrew locked with a wing nut or some such on the back of the upper wheel. Put the blade on so it rides in the center of the tire, (move the guides out of the way if need be until you get the blade to track correctly), and turn the wheel by hand to see how the blade rides. That way you can make adjustments before it pops all the way off. By moving the bolt on the back of that upper wheel in or out you adjust the pitch of that wheel and change the way the blade tracks...
After you get the blade tracking smoothly under tension, you can move the guides back into position to support your blade during cuts.
Posted on Apr 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: blade popping off front wheel
Is the axle tight? Has the tool been dropped to warp the frame? But a quick fix if everything else is OK is to loosen up the axle and put a THIN metal shim on the backside of the axle and then tightening it back down.
Posted on Jul 29, 2009
  • 582 Answers
SOURCE: bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Posted on Aug 22, 2009
REXON BS 10 .3 WHEEL BANDSAW 20 YEAR OLD , WHAT IS MAX BLADE WIDTH I CAN USE . THANKS
open it and measure the drive wheel width . only a guess but 1/2 in might be all
Feb 02, 2017 | Blade Saws
How to keep blades from walking off portable bandsaw model 6225. I replaced bushings on both wheels. Don
Hi Don. have you tried over tightening the blade tension? that works for me
Mar 03, 2015 | Milwaukee Tool Saws
Rexon bandsaw BS12
Read these blogs http://bandsawblog.com/band-saw-wheel-alignment/
http://www.doityourself.com/stry/basic-band-saw-blade-alignment-and-tracking-procedures#b
Apr 12, 2014 | Saws
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
Bandsaw blade keeps coming off the wheels. What
Aug 22, 2009 | Craftsman Saws
Blade popping off front wheel
Jul 29, 2009 | Makita 2107F Portable Band Saw
Bandsaw blade keeps coming off Rexon BS 10
Apr 10, 2009 | Saws
Saws Logo
44 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
