Question about southland Garden Cultivator Tiller S-cv-43 -
Tiller starts but will not run - southland Garden Cultivator Tiller S-cv-43 -
Mantis tiller 7222e
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
Jul 09, 2014 | Mantis 2-Cycle Tiller
I have a tiller from lowes, it starts but won't run.
check that you have good fuel flow to the carb. if it has a fuel shut off valve make sure it is open all the way.
Feb 15, 2013 | Garden
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
My 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Aug 16, 2009 | Craftsman 8.50 Torque Rating Dual...
My tiller starts and runs it also turns the tillers but when I try to till the tillers stop. It is a MTD
sounds like a belt or clutch problem. you didnt give enough info to look up the tiller.
Jul 06, 2009 | Mtd Garden
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
southland Garden Cultivator Tiller S-cv-43 - Logo
59 people viewed this question
Top southland Garden Experts
Dennis Key
Dennis Key
john h
Are you a southland Garden Expert? Answer questions, earn points and help others
