Question about Vitry Health & Beauty
Can you use Vitry nail treatment an CC whitening base together?
Is this whitening procedure safe?
You can consult an expert from Invisalign London to get a most effective and safe cosmetic dental treatment for tooth whitening.
This treatment can be used to enhance the appearance of your smile.
Also, this treatment can be used to reverse the process of tooth discoloration and staining by providing you a younger, brighter smile without any side effects.
Sep 18, 2014 | Health & Beauty
What is the main differences between cosmetic teeth whitening treatment and the teeth whitening treatment performed at the dental office?
The cosmetic teeth whitening treatment is not permanent and gives result only for sometime while with teeth whitening treatment (Zahnaufhellung M?nche) you get free for some years like 5 years. So if you are planning to whiten your teeth i would prefer teeth whitening treatment. Good Luck.
Mar 30, 2014 | Health & Beauty
Teeth whitening
For significant improvements ceramic coverings with veneers or crowns.
For less invasive and moderate improvements use teeth bleaching. Either at dentist office using high concentration hydrogen peroxide , at home in trays with weaker hydrogen peroxide or cheaper less effective off the counter strips/trays
Mar 26, 2014 | Health & Beauty
What are the effective methods available for whitening the teeth?
There are numerous treatments available for whitening teeth according but the best available solution is placing of veneers. In this process of whitening custom made trays which contains whitening solution is being fixed on to teeth so as to get best results. My sister tried out veneer Scarborough so as to attain whitening and she had good results.
Oct 26, 2013 | Health & Beauty
Where to do teeth whitening in Haverhill?
I had a good experience with Pearly White Express Teeth Whitening Center. Take a tour at http://www.pearlywhitescenter.com/
May 17, 2013 | Discus Dental NEW Day White ACP 9.5% Teeth...
Which type of gel is used for teeth whitening?
If you really want to know about the Gel that is used in whitening of teeth than you may have to visit. http://www.pearlywhitescenter.com/
May 02, 2013 | Discus Dental NEW Day White ACP 9.5% Teeth...
Do whitening toothpastes work?
Whitening toothpastes have mildly abrasive chemicals (not bleach) in them that remove surface teeth stains. Some of them have polishing agents that make teeth cleaner and whiter. Always check for the American Dental Association seal of approval. These toothpastes may help out, but they will not whiten your teeth nearly as much as other whitening methods.
Apr 24, 2013 | Health & Beauty
Does teeth whitening toothpaste work?
Because of the short amount of time the gel or paste is actually in contact with your teeth, it doesn't make sense that they would be very effective.
Jan 14, 2013 | Health & Beauty
Health & Beauty Logo
77 people viewed this question
Top Vitry Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Vitry Health and Beauty Expert? Answer questions, earn points and help others
