Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Dyson DC14 Brush Bar won't turn
I have a Dyson DC14 animal. I cleaned the hair off the brush bar and while doing so the bar slipped out of the case (Belt still attached) I put the brush bar back in and put the cover on but now I can't get the bar to turn. I think the bar must not be in right but cannot find a diagram or instructions on what is the correct placement. HELP
  • 1 more comment
  • debnaaron
    debnaaron Jun 13, 2012
    I can't belive this worked. Thank You! I have been fighting with mine for 30 minutes.
  • Steve Rosenberg Sep 09, 2012
    This is great worked for me too.
  • Melissa Bridges
    Melissa Bridges Jun 01, 2015
    I did it too and it worked, took more then 10 clicks but it worked eventually lol
  • 3 Answers
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
Posted on Oct 10, 2009
  • 2 more comments
  • dainfrisby Feb 11, 2011
    You don't specify which way to have the head of the vacume in your lap. I'm assuming it's whatever way will allow for the belt to be on the left side since you mention using your left finger to lift the bar? And do you mean the rounded end is facing up? and the squared off end is facing down? I think these things are a matter of perspective and which way you have the vacume laid down. I just finished cleaning my brush but when I put it back, I get that awful screaming noise you mentioned so I know the brush bar must not be sitting back in the proper position. It sure would be helpful to just have a clear picture in the manual of which way to orient those ends on the brush bar! Your post was still very helpful though...thanks! Back to the drawing board...
  • russ swick Nov 07, 2011
    I wasted the money buying a new clutch and still didnt work. Tried the switching dial trick and YEP it worked!
  • Bree Spann Feb 27, 2013
    This worked for my 8 year old Dyson DC 14! I was ready to call it quits and buy a new vacuum, thinking it had run well for many years. I also needed 2 tries to get this work, and I also had to reset the carpet on/off button and 'reset' the vacuum. Also, be sure to INCLINE the vacuum to get the brush bar to spin. Thank you so much! This saved me from buying a new vacuum!
  • Melissa Bridges
    I also bought a new clutch pretty sure I didnt need it now but oh well.
You will have to take it a Dyson designated repair shop and they will need to replace the clutch. Less than $100 and well worth it!
Posted on Jun 24, 2009
How to get the brush out to clean it ?
Hi there, it's Jack at Dyson.
DC14's brush bar is connected to the clutch mechanism which allows you to adjust the machine for carpets and hard floors. For this reason it's nor possible to remove the brush bar - however you can remove the soleplate to making cleaning the brush bar easier:
Once the soleplate is removed, we'd recommend using scissors to carefully cut away any threads or hair. Please take care not to damage any of the bristle tufts.
I hope this helps, but if you'd like any further maintenance advice you're welcome to call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 25, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Install brush bar dyson dc14 animal
Check the belts, it sound like you have a broken belt or a belt you didn't not reconnect
Feb 05, 2018 | Dyson DC14 Animal Bagless Upright Cyclonic...
I believe the clutch on my dyson "animal" is stuck. It makes this horrible noise when you try to lower the brush roll to vacuum.
Hi its Darran at Dyson.
Your machine is designed to make this ratchet noise if the brush bar is obstructed. We would recommend checking the brush bar and soleplate area and removing any blockages or hairs/threads that are wrapped around the brush bar.
Full details on these checks can be found in our Support section online at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Apr 16, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal handheld brush not turning
We would recommend checking it for a blockage and a removing any hair or fibres from the brush bar.
As the brush bar relies on the suction power of your machine, it would be worth cleaning the filter and checking for blockages as this may cause a loss of suction will in turn stop the brush bar in the Mini Turbine head turning.
If you are still experiencing difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Liaison
Apr 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Have a dyson vacum and the beater bar stopped working. How do you fix the beater bar.
Check that the brush control dial is in the centre position when upright and then moves forward when the head is released. If the brush bar is still not spinning when switched on in the vacuuming position, check the base for blockages and remove any threads or hairs from the brush bar as outlined in your user guide or on our website.
If you are still having difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Jan 21, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
8,006 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
