Question about HP DeskJet 5650 InkJet Printer
Where is my toolbox for hp5650 - HP DeskJet 5650 InkJet Printer
I cant buy toolbox on wildones
You will need to contact Facebook support for that. Here is a link to their live chat:
http://www.facebook.com/note.php?note_id=410099297768
Aug 16, 2012 | Playdom Wild Ones
Windows 7 is not compatible with Teacher's Toolbox 4.0
you may have to upgrade to a newer vertion of teachers toolbox
Aug 17, 2011 | AbleSoft Teacher's Toolbox 4.0...
I cannot check the level of ink in my hp 5610 model printer
You need the HP Toolbox software: Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
How do i check ink levels please? HP C6380 printer
  1. Click Start .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
Regards
Riztech
Aug 28, 2010 | HP Photosmart C6380 All-In-One InkJet...
Ink light keeps blinking on hp deskjet 5650. Followed HP's directions for cleaning cartridges, as the utility that came with the printer does not work on Vista, but still will not print.
Check 16V leg of power supply. I had same problem, but since the carridge and lights worked I assumed power supply was OK. Tried all kinds of things but nothing worked so I replaced the HP5650 with another one. Same problem. Changed power supply and both printers worked. When I put a DVM to the original PS I had the 32V leg but the 16V leg was dead. Who would have thought?
Apr 21, 2010 | HP DeskJet 5550 InkJet Printer
Can't Find HP Printer Toolbox Clean Cartridges Streaks
Opening the HP Toolbox from the Printer Properties
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab
  7. Click Open the HP Photosmart Toolbox .
Or if you are not finding it then put in the Disk and Right click explore - setup folder - tool box folder - look for toolbox.msi - right click and install
u will get the options
Oct 17, 2009 | HP PhotoSmart 7150 InkJet Printer
Help with insterlation of hp5650 printer
installing an hp 5650 printer is as simple as plugging it in and downloading the drivers from Hp.com. type in your model when asked under support tab and they will download to your desktop. I doubt that printer will work with the new Windows Vista, but it should be fine with XP, 2000, 98 or 95.
Apr 14, 2009 | Computers & Internet
Check ink
Printer Toolbox
Use the printer Toolbox to perform the following tasks:
• Align the print cartridges
• Automatically clean print cartridges
• Print a test page
View estimated ink levels -This is what you would click on.
To open the printer Toolbox
  • 1. Open the Printer Properties dialog box.
  • 2. Click the Features tab, and then click the Printer services button.
The Toolbox is displayed.
I Hope This Helps.
Jan 27, 2009 | HP DeskJet 920c InkJet Printer
HP5650 Deskjet Carriage Stuck
hello dear; open the door let cartridge move to center, then UNPLUG the power, try to push the cartridge by hand left to right just investigate see where got stuck what cause this problem I believe you can make it. still have problem let me know.
Dec 29, 2008 | HP DeskJet 5650 InkJet Printer
HP deskjet 940c toolbox
Thanks. Without finding Toolbox ( to Clean/Align my printer) I went to Control>Printer>Cick on my printer>Properties>Services>Clean or Align
Interesting that FixYa manages to intervene when I was trying originally to get to HP !!
Mar 01, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
Seeker5211
Seeker5211
