Question about Husqvarna Garden
I HAVE AN OLD HUSQVARNA 65 L CHAINSAW THAT WAS MY FATHER'S.WAS GAS AND OIL PREMIXED AND IF NOT WHAT KIND OF OIL DOES IT USE.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 188 Answers
Yes, this saw does use mixed oil / fuel. The ratio should be 50:1 and always use a quality FD rated mix oil. This is where cheaper is NOT better.
Posted on Jan 15, 2016
  • 120 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
  • 5 Answers
SOURCE: Husqvarna chainsaw bar bolt loose and leaking oil
had same! was set to release the max amount of oil to bar, but the thread is only so long and will drop out of seat, send it for service and note the bar feeder srew, its faster and cheaper! good luck p.s great saw!
Posted on May 08, 2009
SOURCE: Chainsaw Service manual for Husqvarna in New Zealand
Free download on:
http://lawnandgarden.owneriq.net/ex/thread/view/idThread/278287
Posted on May 15, 2009
  • 323 Answers
SOURCE: chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Posted on Jun 08, 2009
  • 2239 Answers
SOURCE: Cannot find adjustment oil screw on my Husqvarna 61 Chainsaw
The 61 has a 4 position oil pump, the adjuster is a black plastic screw located to the top right hand corner of the pump face, just behind the sprocket, you will have to clean around that area to find it. The pump has numbers 1 to 4 around the screw, 4 being the highest position.
Posted on May 20, 2012
Husqvarna 65 cutsout cuts two blocks
check tank vent and the coil,to see if vent is plugged,and the coil gets hot
Mar 12, 2015 | Husqvarna Fuel Gas Line Hose 501462501 65...
Husqvarna chainsaw oil leaks
I have 4 husky\'s and they leak a little. On the bottom of the saw there is a oil flow adjuster screw turn it down a little also check oil cap gasquet.
Sep 21, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the gas/2 cycle oil mixtuure for a husqvarna 55 chainsaw
These saws were normally ran on a slightly richer mix. The reason was becuase of the mix oil available. I would recommend running a 40:1 or 50:1 mix. Make sure you use an "FD" rated mix oil and Premium ethanol free fuel.
The premixed fuels / oils are even better. They contain the FD rated oil 95 octane fuel and no ethanol.
Jul 20, 2014 | Husqvarna Chain Saw Models 51, 55
Husqvarna 235 is leaking bar oil really bad
Hi, What Kind of oil do You use? A thiker one could be a solution.
Usualy there a other screw (than those H and L of the carburator) to adjuste the amount of oil spend on your blade.
Feb 04, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Need to know the ratio of gas and oil for gas chainsaw 435 16' Husqvarna
Use a ratio of 50-1 with Husqvarna two stroke oil, with other two stroke oils they recommend a 25-1 mix as they do not know the quaility of other manufactureres two stroke oil, always try to use Husqvarna oil.
Sep 25, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What kind of oil do I need to use in my husqvarna 16" chain saw?
Unleaded fuel with Husqvarna two stoke oil mixed at 50-1, for the chain you need a non fling chain oil, both should be available from your local Husqvarna dealer.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the best oil/gas mix for a Husqvarna rancher chainsaw?
50:1 using fresh gas and a modern synthetic saw oil premixed in it's own container. Be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. Don't make up more than a gallon at a time unless your business is sawing. Hope this helps!
Oct 23, 2010 | Husqvarna Garden
Chainsaw lubrication
Use regular bar oil available almost everywhere, not motor oil.
Jun 30, 2009 | Electric Chainsaw Sharpener
Chainsaw gas/oil mix ratio
Jun 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
65 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
