Question about Casio Office Equipment & Supplies
Why casio adding machine won't load paper ? - Casio Office Equipment & Supplies
3 Suggested Answers
  • 566 Answers
SOURCE: Need help replacing the paper roll on a Casio BIG
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Posted on Aug 22, 2009
SOURCE: loading paper in a sharp el-1750v adding machine
i can tell you how in the back there is a **** on lower back slide paper in and push the button that looks like an arrow with ripped paper an it should feed
Posted on Jan 20, 2012
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
What kind of paper does the Casio DR-220 hd calculator use?
The Caiso DR220HD takes a Universal 2-1/4" x 150' Calculator Paper Rolls
Calculator and adding machine paper rolls.
2-1/4" wide. 150' in length. 1-ply.
Your local office supply store shoudl carry this. or order online here:
Free Shipping On Casio DR 220 HD Paper Roll DR220HD
http://www.worldclassink.com/Casio-DR-220-HD-Paper-Roll-printer21507-ift198.html
Aug 12, 2014 | Casio Office Equipment & Supplies
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Loading paper in a sharp el-1750v adding machine
Jan 19, 2012 | Office Equipment & Supplies
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
FR-2650 Plus adding machine
How to install paper tape on a adding machine?
Apr 27, 2009 | Casio FR-2650A Calculator
Error Code E014 Casio PCR-T470
Hi. When they run out of paper, you just load a new roll, and the machine will automatically continue. There is no need to clear the error. It will continue when it senses fresh paper in the receipt side.
Jan 11, 2009 | Casio Parts Cash Register PC Desktop
I am receiving Error Code E014 Receipt Paper for Casio PCR-T470 and do not have any paper to load. I was trying to program PLU #'s and accidently hit some key that printed a huge report and used up all my...
Casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Jul 22, 2008 | Casio DR-T220 Calculator
15 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
