Question about Maytag MSD2651 HE Side by Side Refrigerator
Maytag msd 2651 defrost timer location - Maytag MSD2651 HE Side by Side Refrigerator
SOURCE: MZD2766GES Maytag defrost problem
in fresh food part on top right, remove the housing assy.
Posted on Aug 07, 2008
  • 306 Answers
SOURCE: maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Posted on Aug 22, 2009
aasc
  • 1606 Answers
SOURCE: Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Posted on Jun 13, 2010
  • 1218 Answers
SOURCE: where is the location of a defrost timer in the
Good day,
It is located in the fresh food compartment on the top to the rear of the main controls.
You can tell where the exact location is because a small hole exists where a screw driver can be inserted and used to advance the timer into a defrost mode, or in some cases when the machine is off because it is in defrost to turn the machine back on. The advancing shaft will only turn clockwise.
Posted on Jul 06, 2010
jim_reisinge
  • 23 Answers
SOURCE: frozen evap coil
In the upper food section in the middle of the light/temp control panel.
Posted on Jul 28, 2010
Where is defrost timer reset switch on a Maytag mfd2561heb
This model Maytag has a defrost control board and not a defrost timer. Your control board is located at the top of your refrigerator behind the display.
Jul 28, 2016 | Maytag Refrigerators
Where is the defrost timer in MSD 2732 GR
Timer defrost motors are usually behind the bottom front grille.
Sep 29, 2014 | Refrigerators
I have a Maytag side by side refridge Model # MSD 2436GRW The refirdge side does not feel like it is cooling properly- I have had to move the dial up tp 8-9
There are many different ways a refrigerator will do this. But I will focus on the most likely and that will be either the 68233-2 Defrost Timer or the=> 61005989 Auto Damper Click Here=> MSD2436GRW_Controls and in that photo you will see the location's 13 and 8. Here are the instructions for testing the auto damper=> 61005989 Auto Damper Test Instructions Look into the rear of your freezer and tell me if ice or a layer of frost is covering the rear panel. If yes try to turn the defrost timer clockwise slowly untill refrigerator stops or manually defrost with a hair dryer. If the refrigerator defrost after turning defrost timer then just replace timer. Refrigerator will usally take 25 minutes after that time the refrigerator does not come on simply turn th timer clockwise until it starts. If defrost is not the problem then it is time to test the auto damper. There are a few other test like testing the defrost heater= HERE Here is the freezer compartment parts breakdown=> MSD2436GRW_Freezer_Compartment and part 12 in that photo is the=> 61006116 Defrost Heater Assembly with Defrost Thermostat
I will be here on Fixya or Here if you have questions, Thanks Sea Breeze
If helpful please rate this solution.. Thank You
Jul 19, 2011 | Maytag Refrigerators
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
Defrost Problem
the first thing to check is the defrost heating element, then the defrost limit switch, if good, then its probably the main circuit board.
Sep 12, 2008 | Maytag MZD2766GES Side by Side...
My Maytag side by side freezer/refrigirator MODEL MSD 2554AR is having ice frozen at the botton of the freezer basket.This later melts and form water on the floor of my kitchen.
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Jun 10, 2008 | Maytag Refrigerators
Freezer is very cold refrigerator is warm
you have a defrost problem. could be your defrost heater or your defrost thermastat or i belive yours is a newer one with the electroic defrost timer
Jul 02, 2007 | Maytag MSD 2655 HES 26 cu. ft....
Maytag MSD2651 HE Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
