Question about Texas Instruments TI-83 Plus Calculator
How do I find relative frequency - Texas Instruments TI-83 Plus Calculator
  • Texas Instru... Master
  • 8,073 Answers
You divide the number of occurrences of one data value by the total number of data values.
Posted on Sep 02, 2014
My a6e will not transmit but receives ok. Don't know if I've pressed something by mistake to switch off the transmit function. Checked the instructions and can't find anything relating to the problem.
For some frequencies ,factory/dealer settings , is not allowed to transmit. Only if you reprogramming the radio transciver,but be careful do not disturb the paid frequencies. Stay away of troubles!
Mar 25, 2015 | Radio Communications
What is code 64 as a error message
Error 64,65,66 are related to the same problem
64. (01000000) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency < 66kHz
The Motor Controller module has received signals from the water level sensor (Ptx)
below normal frequency values.
Primary Source: Motor controller module.
Action: Replace Motor Controller module.
65. (01000001) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency > 90kHz
above normal frequency values.
Primary Source: Motor Controller module.
Action:Replace Motor Controller module.
66. (01000001) Pressure Transducer Error [Ptx
Frequency > 90 kHz
Aug 03, 2014 | Fisher and Paykel Washing Machines
What is a relative frequency table
It is a frequency table where the entries are the relative frequencies
relative frequency= (frequency/sum of all frequencies). The frequency can be expressed as a decimal number or a percentage. In that last case, the total of all frequencies will be approximately 100% (due to rounding errors).
May 12, 2014 | Texas Instruments TI-83 Plus Calculator
Two thousand one hundred and twenty frequent business travelers are asked which midwestern city they prefer: Indianapolis, Saint Louis, Chicago, or Milwaukee. 185 liked Indianapolis best, 420 liked Saint...
Hi Omar / Anonymous
2120 total passengers. Subtracting other 3 from 2120 leaves 115 favoring Milwaukee. Divide each number by 2120 for fractional frequencies: Indiana 0.087 SL 0.198 CHI 0.660, MIL 0.054.
For relative Frequency, use the smallest group (Milwaukee) as the base and express the others as multiples of 115. The relative frequency then is MIL 1.000:1, IND (185/115) = 1.609:1, SL(420/115) = 3.652:1 and CHI (1400/115) == 12.174:1
All that said, I'll make a non-accusatory general observation that Fixya isn't and would not be an appropriate place to hunt for answers to homework problems. In the event that this oddly specific question has nothing to do with homework, please ignore the above. If it is homework, please observe the methods used and then go reproduce them yourself to make sore you understand the process and can do it.
Cheers
D
Jan 31, 2014 | Office Equipment & Supplies
Calculate the speed of the wave that has a frequency of 3 GHz and a wavelength of 4mm
For a plane wave in a homogeneous medium, the phase velocity of the wave is related to the frequency and the wavelength by the relation
velocity = wave_length*frequency
In this case
velocity (in m/s)=(4*10^-3 m )*(3*10^9 s^-1)=12*10^(9-3)=12*10^6
Thus velocity=1.2*10^7 m/s
Nov 28, 2013 | Office Equipment & Supplies
Where and how do i replace the vss on a 2002 lincoln Ls
the vss is a variable reluctance or hall effect sensor that generates a waveform with a frequency that is proportional to the speed of the vehicle. if the vehicle is moving at a relatively low velocity , the sensor produces a signal with a low frequency. as the vehicle velocity increases,the sensor generate a signal with a higher frequency. the powertrain control module uses the frequency signal generated by the vss (and other inputs) to control such parameters as fuel injection, ignition control, transmission shifting and torgue converter clutch scheduling
Sep 14, 2013 | Lincoln Cars & Trucks
How do I figure relative frequency
In the context of statistics the relative frequency of a data item (for ungrouped data) or a class (for grouped data) is equal to the ratio of the frequency of the data item or class divided by the sum of frequencies of all the data items or classes multiplied by 100%.
If you want the probability not the relative frequency, do not multiply the ratio by 100%.
Example: In a sample with N data items, a particular items occurs n times. Its relative frequency is equal to (n/N)x100%
Jun 01, 2011 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
49 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
