Question about Hitachi C10FL 10" Stationary Table Saw 3.0HP
How to adjust blade in Chicargo electric table saw?
Not lined up straight with table
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: The saw blade is 1/16
To be that far out of alignment, there must be something loose. Unplug it, turn it over and look for what it is. If you have a drop-indicator gage, and you can clamp it to your sliding miter gage, it will help you get the alignment dead-on. Slide the miter gage toward the front and back in the slot with the tip of the indicator in contact with the blade. Have the the blade at fully elevated postion. If you don't have such a gage, you can clamp a piece of wood to the miter gage to get pretty close. You will probably have to do this with the saw laying on it's backside so that the top and the bottom are accessible at the same time.
Here's the owner's manual
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_OM.pdf
Here's the parts list with an exploded view
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_Breakdown.pdf
Posted on Jan 19, 2010
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
I have a 1/16" tilt
Your question is not very clear. Here are several answers.
By tilt you may be speaking of bevel adjustment 0 - 45 Some saws have hidden under the table or obvious positive bevel stops or screws in the table top for 90 and 45 degree. Adjust them.
You may have a bent or warped blade causing the "tilt."
Thin blades may be stiffened with blade stabilizing washers $14
With the saw unplugged remove the blade. Grab the threaded arbor shaft and pull it up and down. Next push the shaft straight in and out. If there is wiggle the bearings are worn and may need replacing.
Feb 26, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Apr 22, 2010 | Craftsman 10" Table Saw
Cuts in circles,,even with new blade
The saw needs to have the blade guides adjusted properly. There are 2 sets of them . One above the table and one below. They may be solid pieces of steel or they may be sealed ball bearings They are the things that move in toward the blades sides to keep it tracking in a straight line. They need to come in toward the blade as close as possible without touching it. I set mine with a piece of paper as a spacer. set both sets like this and your saw should cut straight. Hope this helps you
Oct 18, 2009 | Delta 28-565 16'' Band Saw Blade 82'' x...
Cutting straight
this is usually caused by a dull blade or you need to carefully re-adjust the blade guides
Aug 12, 2009 | Ryobi 9 in. Benchtop Band Saw
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
I have a Delta heavy duty construction table saw and the blade needs to be alligned to make it cut straight. Nothing appears to be bent. How do I adjust the screws to improve my ctting.
I have the same saw and love it. There are mounting bolt under the table between the blade and the motor. There not ment to be used for adjusting but there is some play. The way to get the best cut is to adjust the fence to the blade. I have a Bessimer fence that adjusts easily with two allan machine screws the push plastic pads against the arms rail. I get cuts that look like DA with 220 was used. Enjoy the saw and good luck.
May 02, 2009 | Saws
Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Craftsman 10" Table Saw
Hitachi C10FL 10" Stationary Table Saw 3.0HP Logo
27 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
