Question about Bosch 500 HMB5050 Microwave Oven
My whirlpool microwave gh5184xps-4 wont heat up food what can be the problem
Turn on but doesn't heat up the food
I have Whirlpool gold GH5184XPS its not heating. how to troubleshooting the problem?
There will be a technical sheet hidden behind the controller assembly or elsewhere.
There is a YouTube video here which shows you how to remove the controller assembly in about 5 minutes.
You can also find it online here.
It may be a bad door switch, controller problem, inverter problem, or defective high voltage part.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 08, 2013 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Locating reset button on my microwave
To my knowledge none have a reset button or circuit breaker. If the unit is total dead there will be (has to be) a fuse inside the unit.
Dec 06, 2012 | Whirlpool Gh5184xps Microwave Oven...
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool gh5184xps over-the-counter microwave no power
There is a high voltage fuse in the unit attatched to the high voltage capacitor, it is the most common problem for microwaves not working. Also check the protective diode,the high voltage capacitor as well as the transformer if the fuse is ok. Good Luck.
Nov 12, 2009 | Microwave Ovens
Microwave has power but wont heat food
Nothing to do with programing if it doesnt heat you have a bad magnaton or a bad capacator. I work on panasonic microwaves every day.
Sep 27, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool GH5184XPS microwave -- no heat
The element is burn out or the reset or hi limit is out.
Mar 12, 2009 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool gh5184xps-4
type in the same info you just typed, in your browser and see what happens.
Dec 07, 2008 | Whirlpool GH5184XPQ Microwave Oven
Bosch 500 HMB5050 Microwave Oven Logo
52 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
