Question about N/A Accentra PaperPro Premium Standard Staples
How do I refill my Accentra PaperPro stapler?
My brand new stapler suddenly stopped folding the staples. It just shoots out singles; good for bulletin board posting-not for stacks of papers. Can this be fixed?
The item on the bottom that folds the staples has two positions. Press it up from the bottom and swivel it 180 degrees to folded staple setting.
May 13, 2016 | PaperPro Compact Stapler, 15-Sheet...
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
Prodigy paperpro spring broke and it stays closed
If you can get the original spring out, it's possible to buy a few common sizes of springs in hardware stores or departments. If you can find one of similar size, it should not be too hard to replace it. You may be able to pry it open with a small, thin, slot screwdriver. If a replacement spring is a bit too long, wire cutters should be enough to cut it shorter and pry out a curl of the spring to hook through the attachment point.
Jun 28, 2014 | Staples One Touch Executive Stapler
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
Paperpro stapler fix
Use one single staple pin cartridge however small.the pushing spring should keep the staple aligned
Aug 03, 2013 | Office Equipment & Supplies
Is there a stapler that can staple over 100 papers, or do I need special eqipment?
Yes, there are some heavy duty staplers that can staple more than 100 sheets: http://www.amazon.com/PaperPro-1300-Stack-Master-Stapler/dp/B000MIJAKG
http://www.amazon.com/Economy-Heavy-Stapler-Sheet-SPR01315/dp/B001D1RO3G
Jan 24, 2013 | Office Equipment & Supplies
My PaperPro One finger 15 sheet power Stapler just stopped stapling. ???
The answer to this problem is simple. When you pull out the mechanism to reload the staples, there is a small metal black piece on top of the mechanism attached to a spring that drives the staples. When reloading, often times the driving piece gets flipped backward. All you have to do is flip this piece over and is should snap back into place. Fixed!
Dec 05, 2012 | Tools & Hardware - Others
I can't find any instructions on how to reload my one-touch stapler. It shouldn't be hard to put instructions on the internet.
I'm new at FixYa, and I don't own this particular stapler, but I'll give this a shot.
Grip the black (middle) part of the stapler on its sides, flip it over (upside-down) and bend the base so you expose what would be the bottom of the black part of the stapler (now facing up, of course, because the stapler is upside-down). There should be a tab near the hinge that you can simply pull to expose the compartment where the staples are stored.
(That's how I reload my PaperPro stapler.)
Feb 21, 2011 | Staples One Touch Executive Stapler
PaperPro 1110 Prodigy metal stapler Has ceased up. How do you open the top to access the mechanism? thanks Gerard
My PaperPro Prodigy stopped firing staples. Examination of the hammer mechanism was fine. (apparently sometimes an internal part can break) Check with stapler opened and no staples. Hold the safety lock pin down with a fingernail or sticky tape so you can check operation of the hammer mechanism. Should withdraw to clear staple compartment and then fire. If this looks good, examine the roof of the staple compartment. Mine had a little lump of brown grunge in the roof of the staple compartment next to the hammer - stopping the staples from sliding up into firing line. Scraped it out and works fine again.
Apr 02, 2008 | Cell Phones
N/A Accentra PaperPro Premium Standard Staples Logo
55 people viewed this question
Top N/A Office Equipment & Supplies Experts
jasbo
jasbo
Are you a N/A Office Equipment and Supply Expert? Answer questions, earn points and help others
