Question about Health & Beauty
Ledsalter scales manuals 9078wh3r
Changed batterys doesn't work.led lights up and goes off.when you stand on scales nothing happens.
SOURCE: hello my taylor 5589 fat scale doesn´t work
Had the same problem with mine and sent it back since it's under warranty. Taylor did not need a receipt and I just received a new scale today, model 5742 although it cost me just about $20 to ship it back and that's UPS ground! The scale retails for $29.99 on amazon.com. Good luck!
Posted on Feb 15, 2010
  • 18 Answers
SOURCE: When i step on the scale, nothing happens - no
Try a new scale. If it works, your old scale is broken.
Posted on Jul 01, 2010
SOURCE: the scale displays 8888 every time you stand on
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
Posted on Jan 31, 2011
drifterK
  • 4924 Answers
SOURCE: I recently purchased a Soehnle
Look around and see if it has a reset button ...and reset it to factory settings ..Probably happened with it ..or cause it repeated you are doing something wrong when you set it .....probably you lock it in the last read ..cause it indicates the same measurement ..So ..all devices like that have to have a reset button ...locate it ..(it may be in the menu as a feature..and called different probably ..factory defaults or factory settings ..or reset all ..) and after you engage the reset it will work again ..but ..read the manual carefully and see what are you doing wrong ...
Posted on Mar 21, 2011
Dane1234
  • 25 Answers
SOURCE: Just purchased the Ideaworks Large Capacity Bath
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Posted on May 15, 2011
Kitchen scales
try changing the battery (s) and see what happens.
Apr 12, 2013 | Taylor Kitchen Scale – (6 lb) ()
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
No power
Yes, the power is working as well as the processor seems to start up the circuit but it ends up with a protect shut down. So it is possible there is some error due to a fault or short within the main board and this might require fault finding using the circuit manual.Remove power remove the main board and look for shorted main capacitors, shorted drivers or open circuit of fusible resistors which can help with fault finding.
Dec 12, 2011 | Epson EMP-TW10H Multimedia Projector
The scale displays 8888 every time you stand on it. If you go to choose p1 it flashes data. Can seem to get the scale to reset using the instructions and removing batteries does nothing
Jan 05, 2011 | Conair WW81 Weight Watchers Body...
Ww17 scale give err display and then goes blank. I tried a new 2032 battery also Can you please advise Joe
You have to turn it on before you step on the scales.
Tap the scales in the center with your foot. lines will appear and then 0.0 then step on to weigh yourself.
Jul 01, 2010 | Conair Large Digital Display Memory...
Just purchased the Ideaworks Large Capacity Bath Scale with infrared receiver and I can't get it to display the weight. The receiver seems to be working (can set clock, lbs, etc. . . ) but nothing happens...
Apr 22, 2010 | Jobar International Ideaworks Remote Read...
Device powers on but will not boot
I have seen this happen when the amount of RAM installed in the computer is higher than what is allowed by the motherboard.
Jun 28, 2009 | Acer Aspire 5315-2153 Notebook
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
