Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Grohe faucet handle doesn't retract
I read the solution, but where is the weight on the hose under the sink? My hose doesn't glide well when I try to pull it back manually from below.
  • 21 Answers
Ok well that is probably the install then.  there is a brass ring under the sink that is holding the faucet tight to the sink.  this has 2 water lines that feed the faucet and the line to your spout.  if the copper lines are not pushed apart enough than it will rub one the line with the weight and make it hard to move up and down. you need to get under it with a flash light and move these lines apart.  The worst  would be that when the faucet was installed the hole was not big enough and that is what it is hitting.  So I hope this help you .
Posted on Jun 25, 2009
Grohe ladylux cafe kitchen faucet: new item, the pull out spray piece does not set firmly into neck so that it falls out easily
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Sep 06, 2011 | Grohe Plumbing
The hose head keeps falling away from the unit. It should stay pushed in
Has no hose weight or not heavy enough weight on hose under sink. either buy a weight and install on hose about 18" from the bottom of sink. or you can use a 3 ounce fishing sinker with bread tie and tie it around hose aprroximately 18" from bottom of sink. It needs the weight to keep the faucet head in.
Aug 31, 2011 | Grohe Plumbing
My Grohe kitchen pull out faucet will not retract
Normally, there is a weight on the hose (under your sink) that retracts the faucet line. Look under your sink and make sure that the weight is still attached and that there is nothing interfering with the hose moving.
Jun 03, 2011 | Grohe Plumbing
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
Grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
Jun 19, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
The pull out faucet is loose, wobbly, won't stay attached.
Make sure that there is a weighted ball connected about halfway down the retracting hose. If not you need to go to a supply house and purchase one and its a simple install.However if there is one attached you can loosen the 2 screws and slide it up closer to faucett but not so far that you can't pull out the sprayer as far as you need. Also make sure nothing is obstructing it under the sink. bottles, cleaners, etc.
Jun 04, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
My grohe kitchen faucet hose won't retract
the first thing you need to check is the weight on the hose under your sink. if it is set too high or to low it doesnt allow the proper weight to pull the hose back into position. also check to see if the hose is twisted under your sink also. I hope these answers will help you out.
Apr 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe 32 071 K4 spewing water from single vale or tube under sink
There should be an o-ring on the mating surfaces of the hose and the faucet that my be missing.  It could also me that the big washer in side of the faucet (under the cartridge) has been shifted.
I doubt it is the cartridge itself, always try the cheap ideas first.
Mar 28, 2009 | Grohe 32.071.KD0 K4 Main Sink Dual-Spray...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
857 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
