Question about Vehicle Parts & Accessories
Code p0105 what is code p105
    New Friend:
    Problem Solver:
  • 20 Answers
Try googling:
P0105 Manifold Absoluter Pressure/Barometric Pressure Circuit Malfunction
or
http://ricksfreeautorepairadvice.com/p0105-manifold-absolute-pressurebarometric-pressure-circuit-malfunction/
P0105 Manifold Absolute Pressure Barometric Pressure Circuit...
Posted on Sep 08, 2014
Code u1000 code p0105 u1152
Codes U1000 & U1152 are related to the digital data bus communications, U1152 is specific for the HVAC control unit data bus. troubleshooting this will require a Tech II scan tool.
P0105 is related to the MAP sensor circuit.
Apr 27, 2014 | 2002 GMC Envoy
Code P0105
The code P0105 relates to the MAP sensor, why are you changing coils?
Apr 09, 2014 | 2002 GMC Envoy
NO POWER TO SPARK PLUG toyota noah 2003 showing error code p0105, p0110, p0115. some one help me plz.
code p0105 refers to manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor--circuit malfunction===causes --wiring---MAP sensor--BARO sensor--ECM
code p0110 refers to intake air temperature (IAT) sensor--circuit malfunction===causes---wiring ---IAT sensor--ECM
code po115 refers to engine coolant temperature (ECT) sensor--circuit malfunction===causes---wiring--ECT sensor---ECM
Dec 25, 2013 | Cars & Trucks
My 2001 Hyundai Elantra is dying alot the engine light codes are p0720, p0105, p0445
code P105 is manifold absolute pressure barometric pressure circuit. code P0445 evaporative emission system purge control valve circuit shorted. code PO720 AT output speed sensor circuit open or short ground.HAVE MANY CODES COULD BE ECM FAILING HAVE DEALERSHIP CHECK OUT ECM.ECM COULD HAVE SHORT OUT PC BOARD.
Mar 12, 2013 | 2001 Hyundai Elantra
Mercedes vito 0105 code what does it mean
they don't let me write in this space all the things I'd need to write for this code, But this link has a detailed instructions on how to check the system , what that code means is this P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction, and this link tells you how to check it in detail http://www.obd-codes.com/p0105
Aug 25, 2011 | Mercedes-Benz Sprinter Cars & Trucks
Loss of power, stalling at stops and slows, codes P0300, P0107, P0105 and P0105. Will stall but when put into nuetral will start right up.
The symptoms and the codes you've given would indicate to me that you have a vacuum leak. Look for a loose a throttle body, loose, missing or damaged hoses, loose or missing intake manifold bolts or any other opening in the intake manifold.
P0105 - Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0107 - Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0300 - Random/Multiple Cylinder Misfire Detected
Jun 17, 2010 | 2001 Pontiac Grand Am SE
P105
it is located on the intake manifold,tocheck turn key on,probe volt.on1st and4th wire of sensor plug normal reading is4 to 5volts if ok,start car let run till norm. temp.probe wires again while car is idling,norm.reading is0.4 to 2volts,if any of these is out of range change sensor
Feb 19, 2009 | 2000 Hyundai Elantra
Vehicle Parts & Accessories Logo
121 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
